View unanswered posts | View active topics It is currently Tue Jun 18, 2019 8:18 am
Reply to topic  [ 16 posts ]  Go to page 1, 2  Next
 How many miles on your 125?
Post How many miles on your 125?
Just bought my new Zuma 125 this past June. Loving the bike, and already have 2000 miles on the odometer. However... as this is my first scooter... I am a little concerned that I am running this thing into an early retirement. At this rate, I will have 15,000 on the bike by the end of next summer. Is that a lot? Am I going to be back at my dealer buying another one sometime soon? Anybody out there with a ton of miles on their 125? What is your experience?
Tue Aug 16, 2011 7:44 pm
scooters and mods: Zuma 125, Battlescooter CVT kit and cluctch, Yoshi exhaust, zumalights dual headlights
Post Re: How many miles on your 125?
Hey, congrats and welcome to ZF!! :toot:
Plenty of reading material here: viewtopic.php?f=47&t=8927
I'm about to clock 4000 miles after just over a year. I think your scoot has plenty more life in her... especially stock!
Tue Aug 16, 2011 8:00 pm
even if you put alot of miles on it, a rebuild is very easy
of course it takes the same amount of work to also throw in a larger piston and cylinder and get more power, and I bet cheaper then buying the OEM stock parts too
so dont worry about mileage as long as you do the oil changes and inspections like the book says
like anything you abuse/neglect it then it wont last long
Tue Aug 16, 2011 8:34 pm
Welcome to the ZForums ...
The 125 in the US has only been with us for since 2009 ... but, as with the Zuma50 ... I'm expecting big numbers for miles -and- a long life !!
Muddy 125 ... does that mean anything like you don't clean it up much ?? Ha !! Ha !! Ha !!
Poor thing !! !!
Tue Aug 16, 2011 10:44 pm
scooters and mods: 2011 Zuma 125 with optional winshield, Koso Afterburner Tail lights and Dual headlight mod
Hi Muddy,
I brought my new 125 home March 17th and have racked up 2600 miles already.
2011 Zuma 125 with OEM windshield, Afterburner tail lights and Zumalights head light mod
Wed Aug 17, 2011 7:51 am
welcome to the forum.
almost 8k miles on mines, granted it's 2nd hand.
http://www.rcscooters.com
Wed Aug 17, 2011 10:44 am
Quote:
"Muddy 125 ... does that mean anything like you don't clean it up much ?? Ha !! Ha !! Ha !!
Poor thing !!"
Yep. I do the scheduled maintenance, but I don't bother to clean it. I kind of like the Mad Max look. I guess if I wanted a good looking scooter I would have bought a Vespa!
Sun Aug 21, 2011 10:18 pm
Muddy125 wrote:
Poor thing !!"
Yep. I do the scheduled maintenance, but I don't bother to clean it. I kind of like the Mad Max look. I guess if I wanted a good looking scooter I would have bought a :piss2: Vespa! :piss:
Sun Aug 21, 2011 10:22 pm
I had 28,000km and needed a repair..carbon between valve and seat, I have 43,508km now and it's dead again with the same problem.
Sat Sep 03, 2016 5:38 pm
did you ever use a fuel cleaner additive
thats supposed to help keep the valves clean
Sat Sep 03, 2016 5:53 pm
No I didn't use anything in the fuel. I always used premium gas, changed the oil every 1000 or 1500 miles. Castrol GTX..
Sat Sep 03, 2016 6:47 pm
is premium high octane?
Sun Sep 04, 2016 7:56 am
scooters and mods: Rattler 110 and a 2011 Zuma
Ever try Seafoam, that stuff is magic. They have a procedure (check YouTube) where you stick a hose in a can of Seafoam form a vacuum line and it sucks Seafoam into your intake and soaks the top end and it will stall the motor. Then you let it sit for hours while it breaks down the carbon deposits. You most likely will need to take out the spark plug befor trying to start it and clean and dry it off with a torch/wire brush and then start it. It will smoke like crazy at first, I would try this a few times if your not able to take the head off yourself and clean it off. Heck lots of oldtimers used to dump a slow stream of water into the intake of cars while running to clean off carbon deposits off of pistons, and it works. Just look at a cylinder thats been running with a bad head gasket or an engine that uses methonal injection. But Im not sure doing the water trick will get carbon off of valve seats, so thats why I suggested the Seafoam trick. After doing that a few times Id suggest changing the oil soon after.
Zuma 125, 2000 BWS100 with Malossi Var/TechnigasRS , Agility125
Wed Dec 07, 2016 6:49 am
I am up to 52,030 kms on the 2011 BW125. Had it in twice for carbon on the valve seats. I am using only SHELL 91 (Yamaha said to use this) and Yamaha Ring Free in every tank of gas. So far so good. I bought a new 2017 but haven't got it yet. Still riding the 2011 BW125.
I was having trouble this winter with it starting...took awhile to start (went on for a couple of months) BUT after I reset the computer it has been perfect.
Mon May 06, 2019 1:56 pm
im up to 281 miles i bought mine in january
Wed May 08, 2019 9:54 pm
