View unanswered posts | View active topics It is currently Tue Feb 19, 2019 4:47 pm
Reply to topic  [ 188 posts ]  Go to page Previous  1 ... 9, 10, 11, 12, 13
 Zuma Stock Speed...What is everyone getting?
Top speed of your stock Zuma
less than 30 1%  1%  [ 3 ]
30-33 3%  3%  [ 10 ]
34-37 21%  21%  [ 73 ]
38-40 32%  32%  [ 111 ]
41-43 31%  31%  [ 106 ]
44-47 7%  7%  [ 26 ]
48+ and Im lying 5%  5%  [ 18 ]
Total votes : 347
scooters and mods: 2011 Zuma, LV exhaust, Simota filter, high flow fan
Post Re: Zuma Stock Speed...What is everyone getting?
Still breaking mine in, but speedo said 47mph this morning and still felt like it had power for more. I'm 6' and 260lbs, so no featherweight here. I had it no more than half throttle. Wish I could hurry up and get some moles on it so I could get on it a bit...........only 34.5 miles on the odometer so far.
Fri Sep 14, 2012 2:48 pm
scooters and mods: 2008 bws 125
i use metric so...
i weigh about 90kg.. and so far the most i've been able to hit is 90kmph. average 75~80 is fine. anything after 80 i need long, level, flat straights
Tue Jan 15, 2013 7:34 pm
dtomas wrote:
i use metric so...
200lb and 75-80 on a stock 50cc zuma?
Sat Mar 09, 2013 10:23 pm
kawasaki_kid wrote:
dtomas wrote:
i use metric so...
profile says he has a 125
Sun Mar 10, 2013 4:59 am
Might be a late post, but my 2009 YW100 100cc2 stroke ( Zuma to anyone stateside) has read 100kph with a tail wind and downhill. Typical flat road it will creep up to 90+ but 80kph (47mph) is normal cruising speed.
Put a GPS on the dash and the top speed doesn't look so impressive :mad: The most optimistic speedo I have ever had.
The current model Zuma selling in New Zealand has the 50cc 3v 4t motor. Went on a childrens charity scooter ride in the company of a 50cc Zuma. It went damn well.
Mon Sep 08, 2014 12:18 pm
scooters and mods: 2014 Zuma 50F: 2 headlight mod, rear fender "tail bob"
Since my Zuma 50F has less than 600 mi, I'm still in "break-in" mode. I have varied the speed and was able to get up to 38-40 mph. I didn't want to linger to long with the throttle opened up, but I just had to see if I was gonna get run over by a cager or what. Anyway, hurry up 600 mi....
2014 Zuma 50F
2 headlight mod
rear fender "bob" (cut the duck tail)
previous bikes: HD, BMW, Ducati
Mon Apr 27, 2015 2:32 pm
Hi all
new guy here
2015 Zuma 50F bare bones stock. I'm a light weight at 125 LB. Best I can get is 42 MPH
with only 3/4 throttle. Pretty sure this thing has a computer with a speed limiter programmed
in it. I can get it going 42 on a flat and then hit the down side of a hill with no speed increase.
My 99 Ford diesel had a speed limiter in it's computer limiting it to 92 mph. A performance
chip fixed that as well as adding 100 hp :)
Do they make chips for the scooters?
Randy
Fri Sep 11, 2015 10:06 am
I ride a 2014 YW50F. I'm 5'6" and about 130lbs. When I first got the bike from the dealership (stealership) it was getting about max 36mph (58kph). I was a little rough during the break-in period, but regular about things like oil changes and such. When I did a full maintenance (filters, fluids, plug and all) around 5k it opened up a bit to 38 (61) average. I've since installed a malossi variator and I'm getting 41-42 (67). I'm pretty sure this is as good as I'm going to get until I go to a BBK or just break down, get my endorsement, and buy a bigger bike.
p.s. My speedo is about 3 mph or so high depending on the ambient temp., so I've used a GPS and local radar to get my averages: I've got about a mile of flat with radars at either end.
p.p.s. To the guy above ^^^... Malossi does make a chip controller. It's supposed to override the built-in ECU limiter. They're like $200 so I imagine it's only worth while if you're going to do a BBK or some crazy race build, but it may be worth giving a shot.
~Cory
Mon Aug 08, 2016 8:12 pm
