View unanswered posts | View active topics It is currently Tue Feb 19, 2019 5:00 pm
Reply to topic  [ 5 posts ]
 Suggestions on Alternate Start/Engine Kill Switch?
Post Suggestions on Alternate Start/Engine Kill Switch?
I have a 2005 Zuma 50cc upgrade to 70cc, not by me. It has a Dellorto pgbg 21 carb and aftermarket throttle. The previous owner tossed the stock start button/engine kill switch, and I can see why, it will no longer fit on the handlebars. The starter itself is missing wires, but using wire with clamps, was able to determine it works. I'd like to get this connected again. Are there any suggestion on an aftermarket, alternative starter button/kill switch? Ideally I'd like to have both. Any suggestions would be appreciated!
Mon Oct 12, 2015 5:24 pm
Post Re: Suggestions on Alternate Start/Engine Kill Switch?
http://scootertuning.ca/en/styling-part ... tage6.html
Everything that you need to hook all that stuff back up to.
They come in 3 colors/finish's
2008 Zuma 50
2012 Zuma 50 (sold)
2003 Derbi Red Bullet
Mon Oct 12, 2015 5:51 pm
Thanks Spaz12, but the throttle I have on there is pretty nice (milled aluminum) although i cant see a brand. Ideally I'd just like the switch(es). Any other option you may know of?
Mon Oct 12, 2015 9:04 pm
Scroll down the page
http://scootertuning.ca/en/211-styling-parts
2008 Zuma 50
2012 Zuma 50 (sold)
Tue Oct 13, 2015 12:38 am
Got IT! Thank you!
Tue Oct 13, 2015 10:08 pm
