View unanswered posts | View active topics It is currently Fri Jul 19, 2019 2:00 pm
 So my C3 smokes my Zuma....thought it was the other way...
Post So my C3 smokes my Zuma....thought it was the other way...
Had a 2009 C3 for a few years, now has 16k miles on it.
Bought a 2009 Zuma with 4k miles because I heard that it, and 2 stroke engine scooters in general, had more power/faster
Both are stock. New spark plug on Zuma (supposedly, just bought it from someone)
Speeds:
Uphill - same, around 28 mph
Downhill - Zuma 44, C3 42
Flat - Zuma 37, C3 41
Hmm....anyone know what gives, or is a C3 just supposed to be faster and what I read is wrong? Thanks!
Mon May 01, 2017 12:53 pm
scooters and mods: 2005 Bws Dual headlite mod1989 zuma with 70cc kit,up jetted carb,dopler air box custom exhaust made outta stock one.
Post Re: So my C3 smokes my Zuma....thought it was the other way.
check the belt on the Zuma.... if your belt is worn out that could explain it
2005 BWS (Blue Bandito)
- 70cc Athena bbk (Sport)
- stock carb,85Mj snorkel removed
- stock clutch
- ncy adjustable td.
- malossi white torque spring
- malossi yellow clutch springs
- michelin bopper tires
- dual headlight mod
- tun'R rear shock
1989 Zuma (Red Dragon)
- 70cc Hebo bbk
- Doppler air box stock carb
Tue May 02, 2017 3:22 pm
First thing with the zuma is to see what main jet is in the carb. If it's a 76 you ot the junk carb. If it's an 80 make sure the throttle mod has been done. Then on to maintenance unless you have proof the belt has been replaced in the last 2 years get a new one check your rollers and make sure your tires are properly inflated
Tue May 02, 2017 7:10 pm
Sounds like something is off with the zuma. My c3 is painfully slow. My zuma 50 2 stroke ran circles around it.
Mon May 15, 2017 11:41 pm
Users browsing this forum: Google [Bot] and 3 guests
