View unanswered posts | View active topics It is currently Sun Sep 22, 2019 4:08 pm
 Backup Gas Tank
Will this Work?
Hell Yea It will work, Why wouldn't it. Lots of people have done it. 0%  0%  [ 0 ]
It will not work because of X Y & Z 0%  0%  [ 0 ]
It will work with slight Modification 100%  100%  [ 1 ]
The Material is not Gasoline Rated 0%  0%  [ 0 ]
I Dont Know, But I love Zumas. 0%  0%  [ 0 ]
Total votes : 1
 Backup Gas Tank
scooters and mods: 2004 Zuma
Post Backup Gas Tank
I had an idea about a second gas tank. Although I'm not too sure if it would work or not. For Zumas that are premixed, I wonder if you could clean out the old Oil Tank and use that as a Backup or secondary Gas Tank. Wouldn't be much, But it would be there in case of emergency. Not too sure if the material its made out of is gas rated. Possibly put a Y Fuel Splitter before the Carb. I'm sure there is someone that has done this and or has figured a way to utilize the space where the oil tank is, or was.
2004 Yamaha Zuma
~ Malossi RHQ Crankshaft 10mm
~ LC Stage 6 MK2 Racing
~ Yasuni C21
~ Polini 24mm Carb | #122 Main Jet | 45 Pilot
~ Polini Gear Set 13/44
~ Malossi Overrange Variator Kit LA Furia Rossa 6x 3.5g rollers
~ Stage 6 Mk2 Clutch/ White contra, red springs engaging @ 7200rpm
~ Stage 6 R/T Clutch Bell
~ Naraku 35mm Intake
~ Stage6 V-Force3 Reed Valve
~ Polini Air Filter (pod/ open)
~ Shock Riser
~ MVT Digital Direct Ignition @ .35 BTDC
~ NGK BPR8ES Spark plug
~ NYC Quick Throttle
~ LED Headlight Mod
~ Trail Tech Vapor RPM meter
~ Trail Tech Temp gauge
Fri Apr 05, 2019 6:23 am
Post Re: Backup Gas Tank
What are you going to do for anfuel shut off how easy is it going to be to access once you run out of gas how far do you think you will get on a quart. Plus the outlet line is a lot smaller then the fuel line from the tank
Fri Apr 05, 2019 4:38 pm
Why do you need the extra fuel capacity.
*Reads through your build*
Oh, that's why. Seriously though, don't think it's likely to be a very feasible idea. If anything, you might be able to use it as additional fuel, feeding continuously with the primary tank. But I think the backup tank idea probably would take a significant amount of toying around to work out all the nuances.
On a separate note, what kind of performance are you getting out of that BBK, pipe, and gearing combo? I'm probably going to be going with a nearly identical combination myself.
Stock '05 Zuma - in the wild somewhere.
2015 Zuma - Stock. For now.
Sat Apr 06, 2019 2:48 pm
Your prob right, It would just be another thing that I would have to worry about. I have enough issues with my Zuma at the moment. Recently stripped one of the Cylinder Studs and now I'm questioning how I should address it. heli-coil, JB Weld?? Re-Tap the threads and go next size up??? Any ideas what would be the best approach to fixing this?? As for Performance when it is running, The 24mm Carb is TOO BIG. It burns up too much gas. Far too much. I can burn through 2 Tanks of 32-1 premix in no time whatsoever. Not to mention its a pain in the butt to tune. Everything is very particular with this setup. Very particular. I recently switched from a Yasuni C16 to a Roost SP1 (SMH) Don't know why I decided to get an almost identical reving pipe. Makes no sense. I should have gone C21 or Roost RS5. Maby in the near future I will go Roost RS5. Still not tuned 100% to this day. The elevation that I am currently at is around 4000 Above sea level, so tuning an already finicky setup just makes it that much trickier. On a good day I can get it close to 65 MPH. But feel prob like everyone else here that I should be going far faster for the amount of $$$ that I have put into it. It's there but where something increases (fuel cons, Speed, Rpm's) the risk of something going wrong increases just as much, If not more due to the variations of parts. The smallest change when squeezing performance out of these scooters the way we do, could be the difference between it running great Or NOT RUNNING AT ALL. Let me know on how you think I should address this Stripped Stud hole. Might even have 2 stripped not too sure (I will have to check)
2004 Yamaha Zuma
~ Yasuni C21
~ Shock Riser
~ LED Headlight Mod
Mon Apr 08, 2019 12:25 pm
Users browsing this forum: Gregorypneup, spanishwomenxfd, VincentWen and 3 guests
