View unanswered posts | View active topics It is currently Mon Sep 16, 2019 8:04 pm
 Need help
Post Need help
I have a 2005 zuma. Did an Athena BBK, had yellow clutch springs went to red. Yasuni Z exhaust. Stock variator and clutch. 4.5 g roller weights. 85 main jet. This thing does not move. Bogs like crazy and doesn’t catch to take off. My brother in law has almost the same exact build but a Leo Vince ZX exhaust. We swapped parts off of his to mine and still same issue. Most of the time his exhaust works on mine but still has a bad bog. The yasuni exhaust is brand new. Had a technigas on before and did the same thing so I thought it was a bad exhaust. Been calling and asking around and trying many diff things and just don’t know what to do anymore. The bike will not even go over 5 mph. There’s no catching to take off.
Wed Apr 17, 2019 5:29 pm
Post Re: Need help
Its not the pipe so lets see what else we can rule out without tearing the cylinder head off and taking a look
Variator check
Is the athena power there just not transferring to the wheel ?
Have you tried half stock and half 4.5 gram rollers
Carb check
Or is it just puking out In the Carb?
What does the plug color look like ?
Is the jet to big or small ?
Is the snorkle out ?
85 main jet is aftermarket jet so I cannot tell from size for sure .
Gears clutch
Does your clutch turn your back wheel freely by hand ?
Does it idle and rev on stand like your brother in laws ?
Wed Apr 17, 2019 7:46 pm
Users browsing this forum: Gregorypneup, VincentWen and 4 guests
