View unanswered posts | View active topics It is currently Mon Sep 16, 2019 7:51 pm
Reply to topic  [ 12 posts ]
 Hey
Post Hey
So I got 04 zuma 2t yas R pipe, I want to sport BBK thinking Of either Top Perf. Polini. or Malossi, which would run most reliably on stock carb ?Also gonna get aftermarket clutch polini malossi or doppler easy s[port kind. Thank you for your help
04 Yamaha zuma
ncy ramp plate Plus secondary pulley ( does alot )
Yasuni R derestricted + Carb Mod
Stock air-box, carb, and cylinder
Gates Long belt 44mph Gps'd
Sun Apr 28, 2019 10:40 am
Post Re: Hey
Any of those 3 cast iron kits will work on stock carb just get the bigger 84 and 82 main jet and possibly the vino pilot jet.
The jets to order 84 main part #14T-14343-42-00 82 main part #14T-14343-41-00
I vote for The malossi for the bbk I just put one on and I am breaking it in on my zuma .
I have bought a second one to go on my wifes vino.
It pushing 46 mph and it is still loosening up .
Before any mods i was 39-40 mph now it basically cruise there .
You can check my build thread" 2004 zuma 50 mph daily driver stealthy upgrades "all though stealth is kinda starting to go out the window
I have the polini 3 shoe clutch and a polini high speed variator stock pipe.
My opinion on malossi vs polini parts for transmission since i have tried both on a sport build they are a coin flip just buy what is cheaper .
Sun Apr 28, 2019 11:22 am
Post Re: Hey
That is awesome I will have to check that out, my pipe got me at 44mph so I think I will be hitting 50 with kit and clutch ( well the stock one would to but prob explode). Thank you for your input on the jets, I also need the right roller weights I am at I think like 5.5 gram now.
04 Yamaha zuma
Sun Apr 28, 2019 11:55 am
Post Re: Hey
The tecnigas next r with the polini variator had me at 44-45 and the yasuni r is a better pipe so i agree that pipe and the right kit would hit 50.
I am breaking in the malossi with stock pipe and running 5.2 grams it runs well all the way to about 6 grams .
With the next R I ran 4.7 with the speeds i was talking.
Who do you buy from the malossi can be found for under 150 bucks at a few different quality vendors.
You will need a wrist pin bearing and I prefer the g clips so over the malossi c clips you can get those a yamaha online or local dealer or order it with your kit.
Sun Apr 28, 2019 2:42 pm
Post Re: Hey
Joshua post up your signature line of what year you are running and what mods over stock so others can help you
Sun Apr 28, 2019 2:47 pm
Post Re: Hey
I am not sure what signature line is, but I got some ncy variator parts ramp plate and torque one in the back, throttle mod, 1500 contra & 1500 clutch springs, Yasuni R unrestricted and everything else is stock. I just now am getting front brake squeaking and it sounds like it wants to grab at lower speeds, gotta fix that asap.
04 Yamaha zuma
Wed May 01, 2019 6:43 pm
Post Re: Hey
I buy from scooterswapshop or scooetertuning.ca
04 Yamaha zuma
Wed May 01, 2019 6:44 pm
Post Re: Hey
Here is how to post your signature
At the very top of this screen it says "user control Panel"
Log in there
On the left hand side of the user control screen under options
Log into profile
2nd one down i your signature
Just update and keep going you also could set up a build thread with your ongoing exhausts .
I for one am very interested in the Yasuni R results rpm range for power band top rpm's and speed
Those are very good vendors .
Thu May 02, 2019 5:47 am
Post Re: Hey
ok
04 Yamaha zuma
Thu May 02, 2019 12:59 pm
Post Re: Hey
Looks good I like to throw my current top no wind speed on my signature for others to reference and compare .
That ncy rear end was that just a shifting up grade or is it larger diameter that also to give better take off
Both those places stock the malossi cylinder with a new wrist pin bearing and the g clips you are around 160 bucks .
Thu May 02, 2019 8:26 pm
Post Re: Hey
It has like different angle than stock so it "shifts" smoother if that makes sense.
04 Yamaha zuma
Fri May 03, 2019 1:47 pm
Post Re: Hey
I know i am ditching my 04 torque driver for a 2008 torque driver it is on back order for that wierd shifting
Is it the same size as the 2004 ?
Fri May 03, 2019 5:58 pm
Users browsing this forum: AnSig, Gregorypneup, latin girlsbyq, VincentWen and 12 guests
