View unanswered posts | View active topics It is currently Fri Jul 19, 2019 2:02 pm
 Rear wheel wobble
Post Rear wheel wobble
I have a 2008 Zuma and noticed while in the kickstand the rear wheel has a pretty good wobble to it. It’s not the tire, I held a steady screw driver next to the rim and it would rub, then not etc. Are these rims known to bend? The scoot is new to me so not sure what kind of abuse it had. I can’t imagine this is normal. Any suggestions?
2008 zuma. Throttle mod, 6.5g rollers, stock exhaust, 80 main jet in carb. Top speed 37mph.
Sun May 19, 2019 6:45 pm
Post Re: Rear wheel wobble
Not normal
Curb Jumping will do that .
Aluminum rims do bend
2004 Zuma Malossi sport 70 cc Technigas next r 2008 zuma torque driver polini high speed variator 5.5 grams sliders malossi delta clutch yellow contra yellow clutch springs Stock Carb 82 main jet 46 pilot jet needle 1 clip rich stock athena 14/42 gears 11 to 1 final ratio 56 mph
Mon May 20, 2019 6:18 am
I will have to look into the axle being bent or the rim. It really does not seem to affect the ride so I will just leave it for now.
Tue May 21, 2019 10:50 am
Users browsing this forum: Google [Bot] and 6 guests
