View unanswered posts | View active topics It is currently Wed Aug 21, 2019 5:01 am
 MVT Digital Direct Ignition System
scooters and mods: 2004 Zuma
Post MVT Digital Direct Ignition System
I just got the MVT Digital Direct Ignition System for the 02-11 Zuma But I am having issues wiring it. I have tried all the possible wiring configurations. white to white, white to yellow, white to yellow-white, yellow to white yellow etc.. I am not getting spark for whatever reason. No go. Anybody ever wire one of this inner roter ignition systems up? If so, How did you wire it? Any insight would be helpful.
File comment: I Went Based off this Wiring Diagram.
60792358_10219116195557071_7498447758429257728_n (1).jpg [ 38.18 KiB | Viewed 167 times ]
2005 Yamaha Zuma
~ Malossi RHQ Crankshaft 10mm
~ LC Stage 6 MK2 Sport Pro
~ Roost SP1
~ Polini 24mm Carb | 124 Main Jet | 45 Pilot Jet
~ Polini Gear Set 13/44
~ Malossi Overrange Variator Kit LA Furia Rossa
~ Stage 6 Mk2 Clutch
~ Stage 6 R/T Clutch Bell
~ Naraku Intake
~ Stage6 V-Force3 Reed Valve
~ Polini Air Filter (open)
~ Shock Riser
~ NGK Hot Plug
~ NGK BPR9ES Spark
~ NYC Quick Throttle
~ Headlight Mod
~ Trail Tech Vapor RPM meter
~ Trail Tech Temp gauge
Mon May 20, 2019 7:42 pm
Post Re: MVT Digital Direct Ignition System
I can see if the pdf is available, what model is it?
DD-19 or DD-06?
2007 Yamaha C3- http://c3riders.freeforums.org/vox-on-wheels-t578.html
Malossi variator, malossi drive face, 5.5 sliders, white contra, malossi torque driver, lightened flywheel, malossi clutch springs, stage 6 wing bell, ported throttle body, uni filter, custom exhaust, dynojet fuel controller, feign unlimited rev box
Tue May 28, 2019 9:07 pm
I think it's the DD-19 for the 02-11. Have tried all different configs. tried black white to brown on the MVT, white to white, White to yellow, White to Yellow Red, Yellow to Yellow Red, etc. Not getting any spark. The battery is fully charged. The bike runs fine with the stock ignition. Why is it that there are no real clear instructions on how to wire these things up. And the info that I am getting is All in a different language such as French, where the Translations are straight Garbage. One video on youtube seems to explain this somewhat but again, the translations are garbage.
2005 Yamaha Zuma
~ Roost SP1
~ Naraku Intake
~ Shock Riser
~ NGK Hot Plug
~ NGK BPR9ES Spark
~ Headlight Mod
Fri May 31, 2019 11:47 pm
