View unanswered posts | View active topics It is currently Sun Sep 22, 2019 4:09 pm
Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
 Samurai 164cc engine kit
scooters and mods: PGO PMX 110 @ 123cc with some serious mods / G-MAX 200 @ 231cc with even more mods / BWS100 @ 100cc with stunt mods
Post Samurai 164cc engine kit
This package is availible right away, orders received during monday-thursday will have this shipped within 48 hrs.
This is a combination of our latest 155cc big bore kit and the newest 3mm stroker crank.
No case work needs to be done, just a strip and rebuild with the new parts, everything bolts right in place!.
Heres whats in the box:
forged 58.5mm piston with teflon coating
58.5mm cylinder
gaskets and rings
3mm stroker crankshaft with CNC rod
Highlift cam
Lightweight cam pulley
10 hole injector
Price $550
Shipping $65
total displacment is 164cc.
You will require an aftermarket exhaust and at least a clutch upgrade.
Compression ratio will be around 10.5:1- 11.0:1 so high octance fuel is reccomended.
We also have titanium retainers, lightweight valves and firmer valve springs availible as an option for another $100.
First 3 orders get a balanced crankshaft with a lighter connecting rod for free :D
picture shown is of a balanced crank
Wed May 27, 2009 11:08 pm
Post Re: Samurai 164cc engine kit
Does it include the oil cooler as well? Will a power commander or something similar be necessary? I was about to order a 155cc kit from you as well as some other things but this looks interesting...
Samurai 164cc kit, hi lift cam, titanium valvetrain, aluminum oil cooler, yoshimura carbon fiber exhaust w/ black ceramic coated header, malossi multivar, rrgs clutch and bell, dunlop tt92 tires, uni-pod filter, dual 35w/35w, C3 mirrors, led taillight, led turn signals, 12 volt adapter, foot peg bars, pro-taper handlebars, death grips,
Thu May 28, 2009 9:55 pm
It works without a power commander but it can benefit from having one added later. ( i just added one a few hours ago and its faster than without)
Also the oil cooler was deemed to be not required, only for much larger displacement.
I also sell the 155cc big bore kit by itself for $250 with the cam, cam pulley and injector.
Fri May 29, 2009 11:53 am
scooters and mods: no scooter anymore!!! dookie got stolen and tossed out the back of a truck, bent frame had to part it out
what is up dan. i was wondering if i could buy like 4 head gaskets for the 155cc kit? if you can get them that would be sweet.
not a damn thing!!! dookie got stolen and tossed out of a truck.. bent frame all to hell.. no funds to repair so parted my beast out and now im looking for a used z125 to murder
Fri May 29, 2009 8:10 pm
shoot me an email :D
Quick answer is sure, just $5 and postage costs :toot:
Sat May 30, 2009 9:35 am
What's up smelly.....
If I order this weekend will I get a balanced crankshaft and connecting rod as well? I can't wait to be one of the first to check it out!
Thu Jun 04, 2009 8:26 pm
If you order over the weekend i should be able to have it sent by tuesday.
Along with the balancing and lightweight rod :D
Fri Jun 05, 2009 4:23 am
scooters and mods: RRGS frontend conversion and rear shocks, CVT kit and clutch, Koso mirrors, SBL swingarm, Two Bros exhaust
What is the ideal roller weight to use with the 155cc kit to get the best all around performance?
Mon Jun 08, 2009 2:40 am
Well this thread is for the 164 kit but if i remember correctly, its 1g higher than stock and another .5 higher with this kit.
Higher than what.... well thats up to you as some people like 11 others like 10 etc.
Its always fun to swap and try it out, you will be amazed with the difference rollers make!.
Mon Jun 08, 2009 6:16 am
scooters and mods: Black Zuma 125: 155cc Kit, High Lift Cam, AFR gauge, K&S mapping unit, RRGS trans upgrade, Koso Mirrors
The 164 is 155 kit with the stroker crank, right?
Also, you've got the cam and 155cc kit on your project bike, right? All you're using is the larger injector. When you pull the plug, the color is good? Looks like it's running well, mixture wise?
Z125: RRGS:Variator, torque spring, exhaust, Cam, 155cc BBK, clutch&bell, Koso mirrors, DynoTune AFR gauge, K&S FI mod, LED taillights
Mon Jun 08, 2009 8:32 am
Yep its a nice light tan brown colour, running very well indeed.
No ECU, just a larger injector.
164cc kit is the 155 kit with a stroker crank, so the option to upgrade from the 155 kit is there :D
Mon Jun 08, 2009 11:27 am
scooters and mods: Yellow 2009 Zuma 125 - blue 2009 TMAX -2005 green Vespa GT 200L
Me likey!
- - Ride a scooter. Be a hero.
Thu Jun 11, 2009 7:52 pm
Dan I am still running lean with the K&S will the 10 hole injector fix my problem?
2009 Zuma 125 Black Laing Huei Racing 155cc
2003 Zuma 50 Silver
Fri Jun 12, 2009 8:19 pm
You should be able to ditch the K&S and just use the 10 hole injector, yes.
Sat Jun 13, 2009 3:40 am
scooters and mods: 09 Zuma 125- Two Brothers Exhuast, Koso mirrors, progrip 901 grips, dashboard mod, cold air intake
Hey Dan,
Ru still including the balanced cam shaft and connecting rod? and there's no chance in a price decrease?
Mods: TBR CF Exhaust , Malossi Varriator w/ 13g rollers, Samurai 164cc bbk, Titanium Valves, Koso Clutch & RRGS Bell, custom cold air intake, HID Lights
Tue Jun 16, 2009 8:20 pm
Users browsing this forum: Gregorypneup, spanishwomenxfd, VincentWen and 3 guests
