View unanswered posts | View active topics It is currently Sat Sep 14, 2019 11:10 pm
Reply to topic  [ 16 posts ]  Go to page 1, 2  Next
 Does anybody here run a tach on their Zuma 50?
scooters and mods: 02 stock Zuma...05 radical Zuma racebike...
Post Does anybody here run a tach on their Zuma 50?
I'm curious what kind of RPMS you're pulling either dead stock or with a 70 BBK and pipe.
I have a suspect ACEWELL tach that has a wire you wrap around the ignition coil lead. I notice that if the rubber insulation is thick where the wire is attached.......the tach reads idle at 1700 minimum. If the wire is wrapped around a thinner part of the ignition lead ...it will read 300 rpm higher...or 2100 at idle.
Maximuim revs is see on this tach is 10,300 RPM downhill. It won't pull higher.
Has anybody seen a Zuma 50 with a stock crank rev past 10.3 ??? I'm guessing the real top RPM on a stock crank is 9500 to 9700.
If you run a tach on your ZUMA 50.....post up your IDLE and maximum RPMS.
THANKS
Wed Aug 05, 2009 12:00 am
Post Re: Does anybody here run a tach on their Zuma 50?
I think my tach goes up to 14K. I run at about 12-13K. My scooter doesn't even move until I hit 8K
Don't know what I idle it. I took out the battery so the tach doesn't work unless the motor's churnin.
Thu Aug 06, 2009 12:39 pm
scooters and mods: 03 zuma athena crank 70cc kit reeds and clutch. 17.5mm carb and a leo 70cc pipe.
i have a mychron data gauge it will read to at least 16000 rpm. i share it with my race kart and have seen the kt 100 rev that high. the zuma hits a wall at 10322 rpm. i do have a athena crank.
Fri Aug 07, 2009 12:13 am
scooters and mods: '08 Zuma 70, Old scooters.... SR50 stock and an SR70 Heavily modded.
That doesn't sound right at all.
What kind of tach is it and how do you have it hooked up please.
Sat Aug 15, 2009 1:50 pm
I was looking into the Acewell 3950 Series myself Canyondancer.
Feels like riding blind when I don't have an RPM gauge.
Which idle is more accurate 1700 or 2k
Sat Aug 15, 2009 1:59 pm
I find it really tough to tune the trans without a tach. If you do buy that ACEWELL .....the yellow wire is for the tach. Run the yellow dirctly to the positive lead on the coil. That works better than wrapping the wire around the spark lead. The most i've seen on my tach is 10,300 with the stock gearing. I can only pull 8700 now with the up gears.
Sat Aug 15, 2009 4:14 pm
Idle - 1800-2200 rpm, depending on ambient temperature and my Zuma's mood
Stock clutch engagement - 3600 rpm
40 mph - 8800 rpm
this is on a stock 04
2005 Yamaha Zuma 50 - dual headlight mod, Koso tach, Leo Vince ZX pipe
Thu Aug 27, 2009 5:58 pm
scooters and mods: 2009 Zuma 125-C3 Mirrors, GPS Ram-Mount, Stebel M80 Magnum low tone horn, KS/BTX Forward Pegs, Rear Rack w/ GIVI trunk
I just adjusted my idle to run at 1850 after a four minute warm-up. I wrapped the coil about 2 inches from the top of spark plug cap. I don't have it mounted so I can't tell you how high it goes.
I'll have to take it on the road and see.
2009 Zuma 125 picked up 9/21/2010 with 9/10 of a mile on the odo
KS/BTX Forward Pegs, Rear Rack with GIVI trunk
Clocks4Bikes Handlebar Clock, Termoscud Lap Apron (seasonal)
VA Tag: 96 MPG
Rolling Thunder/Ride of the Patriots 2012
Rolling Thunder/Ride of the Patriots 2011
Member # 1807
http://www.facebook.com/steven.levine1?ref=name
Gone, but not forgotten:
2008 Zuma 50--FAREWELL PARTY-SEPTEMBER 30, 2010
Co-SOTM November 2009
Rolling Thunder/Ride of the Patriots 2010
Thu Aug 27, 2009 6:49 pm
40 mph - 8800 rpm
Thank you sir.
Thu Aug 27, 2009 7:56 pm
Still trying to locate a gauge that I like, but I'll post when I get one installed.
Sat Aug 29, 2009 8:06 am
I hooked up the tach today to see what's going on. Temp. was 72, so a perfect day for the engine.
I ride a 2008 Zuma 50 stock except for throttle mod.
Idle is about 1850.
At 42 mph, flat grade, more or less, it got up to 8500 rpm and I thought it was still climbing, but I ran out of real estate.
Uphill, it never got over 7100 rpm. Does that make sense?
VA Tag: 96 MPG
Member # 1807
Tue Sep 01, 2009 6:46 pm
Sounds right...thanks.
Wed Sep 02, 2009 12:59 am
My current partial setup.
2008 Zuma
70bbk
12k crank
17.5mm carb
Leo ZX
6g rollers
OEM belt
Malossi 2000 Multi
Red Contra
Idle = 1855
Under Acceleration = 9130
Top RPM at 60 mph (GPS) 9520
I will post back when I install the racing carb and exhaust and put 4g rollers in
Sat Sep 19, 2009 11:22 am
scooters and mods: 2000 yamaha zuma
i can get up to 10000 rpm at not even half throttle i havent tried going over that. my idle is about 2500 and 3000 rpm. any lower on the air screw and it wont idle. would a leak in the exhaust cause this? would the rollers weights cause this? would the engine not being broken in cause this? ive been trying to get it to idle lower yesterday and today. no luck. i love my tach everyone should get one
00 ZUMA
front turn signals relocated
Pirelli SL26
LV SP3
Malossi 70cc cast iron kit
Malossi front brake pads and rear shoes
Malossi variator
Malossi delta clutch
Thu Oct 22, 2009 4:54 pm
Not trying to give you a hard time...but your "new" tach is junk. If it won't idle lower than 2500....the tach is not accurate. Half throttle at 10k with a cast iron 70 can't be done. The tach is junk.
Thu Oct 22, 2009 8:39 pm
Users browsing this forum: Gregorypneup, VincentWen and 1 guest
