View unanswered posts | View active topics It is currently Sat Sep 14, 2019 11:12 pm
Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
 OMG...can it be true? Top speed wars......part 27.
scooters and mods: 02 stock Zuma...05 radical Zuma racebike...
Post Re: OMG...can it be true? Top speed wars......part 27.
Sway wrote:
My modded BWs NG pulls 68mph on a flat road at top speed, and this has been confirmed by GPS yesterday. I don´t even have a speedometer, so the only way I can check speed is a TomTom GPS.
Not without an up gear kit you aren't. Stop smoking crack....it's bad for you.
Wed Sep 02, 2009 5:00 am
scooters and mods: See forum signature
Indeed I am. My European Zuma is completely different than yours - it has a completely different engine which has a much higher compression ratio, and has always been faster than the US Zuma. I was doing 50mph when the scooter was stock.
Believe me if you want to or not, I really don´t care, all I know is that I am hitting those speeds every day.
2008 Yamaha BW's Next Generation Naked "Sway Edition"
Hebo 70cc Kit
Leo Vince ZX Chrome
21mm DellOrtho Carb
Hebo Racing Clutch
Hebo Racing Variator
Michelin Bopper tires
YSS Performance rear shock
Wed Sep 02, 2009 5:08 am
If it's different than ours....and we are talking about U.S models.....WHY did you post at all?
Wed Sep 02, 2009 5:12 am
Please give me a good reason, in relation to the purpose of Zumaforums, why I should not post? Are you saying that a Canadian member with a BWs cannot post, because his scooter is similar to the US model, but not quite the same?
Hebo 70cc Kit
Leo Vince ZX Chrome
21mm DellOrtho Carb
Hebo Racing Clutch
Wed Sep 02, 2009 5:25 am
For the same reason you don't compare apples to oranges. It's a waste of time and means nothing.
I'd be happy to learn all about European 50cc Zumas...and i'd be happy to be friends with someone from Portugal. But to compare top speeds from apples to oranges is kinda stupid no?
Wed Sep 02, 2009 6:21 am
On my stock cylinder, airbox and carb I hit 56mph (GPS) downhill. Then zuma felt stable, but the engine sounded like it was on its way to destruction.
2005 Yamaha Zuma 50
58 mph (GPS)
0-40mph ?? Seconds
Malossi Sport 70cc BBK - Stage6 PRO Exhaust - Dellorto PHVA 17.5mm 92MJ, 34Idle, A12 Needle Up One Position, Snorkel Removed - Athena Primary Drive Gear - Nology Hotwire - Malossi Reed Cage - Malossi Multivar - Stage6 Rollers 30g - Malossi Delta Clutch - Malossi Wing Clutch Bell - Malossi Torsion Controller - Malossi Yellow Contra - Motoforce Racing R6 Rear Shock - Slipstreamer Windshield - Dual Headlight - Triple Brake light - EMGO Trunk - Ram-Mount for GPS
Wed Sep 02, 2009 7:04 am
Mine did the same but i had no idea how fast i was going back then with just a stock speedo. I think that CDI box has a rev limiter around 10.5 11 k because the engine sounds like it's 4 stroking at that rpm.
56 mph is a LOT of mph with stock gearing. Must have been a long long downhill run. I'll bet you had the windsheild on it. Those sheilds are good for 2 or 3 more mph on the top end.
Wed Sep 02, 2009 8:45 am
scooters and mods: '08 Zuma 70, Old scooters.... SR50 stock and an SR70 Heavily modded.
Unless a video of this is shown, I'm calling the BS flag.
Wed Sep 02, 2009 6:37 pm
Yeah, it was long and steep with a tailwind!
2005 Yamaha Zuma 50
58 mph (GPS)
0-40mph ?? Seconds
Thu Sep 03, 2009 7:02 am
scooters and mods: 04 zuma 50 stock but not for long :)
canyondancer wrote:
Wish somebody would explain how these different ratios are mathematically calculated. A lot of us would be interested to know.
Do all those upgear kits use 40 for the primary gear?
no athena uses a 50 primary gear 15/50
malossi uses a 40 16/40
polini uses 40 16/40
Pro Scooter Parts Authorized Dealer
Polini / Malossi / NCY /Metrakit / POSH / Doppler / Leo Vince / Athena
Visit us today at http://www.proscooterparts.com
60+ mph club 70+ when i can show the proof :)
Thu Sep 03, 2009 3:09 pm
Hey Jude....where did the 15/50 come from? No such a thing?
Fri Sep 04, 2009 7:43 pm
scooters and mods: '08 Zuma, '99 Zuma
Team Calamari shows
Athena 15 X 50
Polini 13 X 44
Fri Sep 04, 2009 10:37 pm
its what my athena gear has 15/50 even says so on the box it came in
Sat Sep 05, 2009 10:27 pm
scooters and mods: 2009 Zuma 125
Today I was installing a set of gears on my friends 08 Zuma. These gears must be pressed in unlike the 139QMB I am more accustom to. Anyways I did a search of Athena Gears and this post came up and I thought I would add what I found today to the discussion.
My set of Athena Gears from Parts Unlimited are 42/14 Part number 1106-0004
Overall the install was fairly easy just have to be careful of the bearing when you remove and reinstall the driven axle. Athena dosent include any instructions or gaskets with this kit, sucks.
Well this is my first post and with 3 of my friends with Zumas and my Zumaruckus Im sure you'll be seeing me around.
:piss2: :2bong: :piss:
10% Member Discount Code "Zumaforums"
Image ImageImage
Wed Oct 28, 2009 6:59 pm
Users browsing this forum: Gregorypneup, VincentWen and 1 guest
