View unanswered posts | View active topics It is currently Wed Sep 18, 2019 2:57 am
Reply to topic  [ 9 posts ]
 WTB ZUMA 1 Brembo caliper
scooters and mods: 2008 Zuma 50 w/ 150cc GY6
Post WTB ZUMA 1 Brembo caliper
As the title says, I'm looking for a Brembo caliper from a Zuma 1. I purchased one via Ebay.uk but for some reason it has yet to arrive.
Sooner or later I can put my front wheel back on if I can find a replacement caliper.
John
'08 Zuma
GY6 150cc
'04 Zuma
Burgman 400 install
Wed Sep 30, 2009 7:10 pm
scooters and mods: modded 05 zuma and 06 R6
Post Re: WTB ZUMA 1 Brembo caliper
Its not a Brembo but similar and offered in colors.http://scooter-center.com/scoweb/pages/ ... erItems=10
viewtopic.php?f=50&t=5614&start=300
Sun Oct 04, 2009 5:12 pm
have 02 and up caliper with the rest of the brake parts in for sale thread....
Wed Oct 07, 2009 8:30 pm
An '02 single-piston caliper is the same as the '08 version that I already own.
John
'08 Zuma
GY6 150cc
'04 Zuma
Burgman 400 install
Sat Oct 10, 2009 7:13 pm
a Brembo caliper from the Piaggio Typhoon 50cc or 125cc scooter will fit the Zuma fork directly, some Yamaha Jog scooters came with Brembo calipers stock from Japan & the Yamaha Aerox has Brembo calipers standard.
here is a pic of my creation, a Beta Ark scooter with a Yamaha Aerox front end conversion using a 280mm wave disk & Brembo caliper.
Overrev Tuning
Yamaha Aerox R
MHR Team 6T 70cc (max tuned) + MHR Team Crank + SKF 6204 TN9 C3 bearings + Malossi VL12 reedvalves + Yasuni C21 exhaust pipe + Keihin PWK28 carb + PVL digital inner rotor ignition + Polini Evo SS9 vario kit + Bando belt + Polini 128mm rear pulley + Malossi red vario spring + Malossi Torsion Controller + MHR black clutchsprings + Delta clutch + Wing bell+ Polini 15/42 gear kit + Malossi RS24 rear damper + Bridgestone Racing Battlax tires + Aprilia rally 12" wheels
my "humble" trackday toy, 90+mph.
Sat Oct 10, 2009 8:21 pm
scooters and mods: '08 Zuma 70, Old scooters.... SR50 stock and an SR70 Heavily modded.
Looks like the caliper from my '07 SR50 Aprilia also.
Sun Oct 11, 2009 10:09 am
Thanks guys for the input on where to find one. I'm eyeballing one right now on Ebay. Granted it is a few bucks more for this one but at least it is in the states. Fingers crossed.
OverRev, where did you get that caliper spacer bracket? Did it come with the stage 6 280mm rotor?
John
'08 Zuma
GY6 150cc
'04 Zuma
Burgman 400 install
Sun Oct 11, 2009 12:32 pm
yes it came with the disk rotor.
Overrev Tuning
Yamaha Aerox R
Thu Oct 22, 2009 9:15 pm
Well, after an exhaustive search for a decent caliper, I ended up with a twin-piston Brembo sourced from a Piaggio x9 500cc scooter. Though I will ultimately end up machining two adapter brackets, one for the stock caliper and the aforementioned, to see which one has better feel for the power that this little engine makes over the 2-smoke.
Pictures forthcoming.
John
'08 Zuma
GY6 150cc
'04 Zuma
Burgman 400 install
Fri Oct 23, 2009 7:20 pm
Users browsing this forum: adelatc2, Gregorypneup and 6 guests
