View unanswered posts | View active topics It is currently Tue Sep 24, 2019 2:37 am
Reply to topic  [ 11 posts ]
 Kawasaki 2 Cycle oil
scooters and mods: 2005 raven zuma, Stage 6 sport 70cc, LV ZX and Malossi Fly Clutch.
Post Kawasaki 2 Cycle oil
Anybody ever used Kawasaki 2t oil? It's at our big lots for $2 a quart, Thinking about stocking up, even if it does smell kinda bad.
Let me know :patriot:
2005 Zuma 50, Under construction
Tue Oct 20, 2009 3:48 pm
scooters and mods: 2008 Yellow BWs 50: PHVA 17.5 mm carb, YES Muffler, TP Trophy 70cc, Malossi variator & clutch, JDM tail
Post Re: Kawasaki 2 Cycle oil
Personally, I'd stick with a good quality full synthetic oil rather than a "low ash" type. Less smoke and (probably) better lubrication. And smell.
Think of it this way... would you put Lawn Boy oil in? Similar type and quality of oil.
YELLOW 2008 BWs 50 - Zumaforums Member #2057
dual headlight mod, C3 Mirrors, TinyTach, JDM Tail light, Low Canadian OEM windshield
Top Performances Trophy 70 cc, MotoForce 17.5 mm PHVA clone 90 main jet (still tuning) with Stage6 Choke lever next to key
Malossi Variator 6 x 5.5g rollers (still tuning) Malossi Delta Clutch Red springs, (still tuning) Malossi Yellow contra spring (still tuning)
YES Muffler(Canadian, eh)
Stage6 43/13 Primary gears. 10.94 final drive ratio
COMING: STR8 oversized fan, Motoforce Evolution crank
70 cc of scootin' pleasure
Tue Oct 20, 2009 4:07 pm
Ok I poured some of the oil into a water bottle.
It's nasty stuff, I may not even use it, or I may mix it with yamalube (no disaster side effects)
My main concern is the viscocity of it. Both oils are at room temperature. The second photo is 10 seconds after being swirled around (to run the oil up the side of the bottle)
Tue Oct 20, 2009 5:46 pm
pics
File comment: kawasaki 10 secs after shaking
File comment: Yamalube 10 secs after shaking
File comment: Kawasaki
Tue Oct 20, 2009 5:50 pm
Stuff smells pretty awful, but so does yamalube
Tue Oct 20, 2009 10:45 pm
scooters and mods: 2008 Zuma, Dual Light Mod
Yamalube Oil looks cleaner then Kawasaki Oil
2008 Stock Zuma (Blue)
- Dual Light Mod
- T-Mod
- Michelin Reggae Tires (not yet installed) Still Running Stock Tires
- (Currently 5649 Miles)
6115 Miles
7120 Miles
7398 Miles 2/15/11 Rear Tire Changed
:rock:
1998 Jeep Wrangler Sport
2008 Jeep Wrangler X
:science: :siren:
ZF Member # 271
Check out my Gallery.
http://www.zumaforums.net/Gallery/v/v3511/
Tue Oct 20, 2009 11:19 pm
From what I know the yamaha oil is semi synthetic. And the kawa oil is full mineral oil
They both have the same additives though, and both say they are suitable for injector use.
Wed Oct 21, 2009 9:27 am
Suitability for injector use is probably a viscosity thing. Too thin or thick will give weird pumping characteristics.
Wed Oct 21, 2009 10:37 am
Claims it's suitable for injectors but idk. I can't say I full trust it.
Is it ok to mix it with yamalube? Like a 50/50 ratio?
Wed Oct 21, 2009 10:50 am
Mixing oil types should be avoided if possible, especially when the two oils are of different base (mineral vs. synthetic).
Wed Oct 21, 2009 12:21 pm
I would not trust Kawasaki 2t oil, they don't even make scoots, not to mention 2 Stroke scoots.
- Dual Light Mod
- T-Mod
6115 Miles
7120 Miles
:rock:
:science: :siren:
ZF Member # 271
Wed Oct 21, 2009 8:56 pm
Users browsing this forum: Andrewodory, Gregorypneup, VincentWen and 2 guests
