View unanswered posts | View active topics It is currently Tue Sep 24, 2019 2:22 am
Reply to topic  [ 8 posts ]
 carb buy
Post carb buy
i have 05 zuma and looking for a carb for it, i just want a stock one ty
Tue Oct 20, 2009 5:40 pm
Post Re: carb buy
bump
Tue Oct 20, 2009 10:27 pm
Post Re: carb buy
guess noone carries stock anymore
Thu Oct 22, 2009 12:09 pm
Post Re: carb buy
http://www.teamcalamari.com/zuma/garage ... esale.html
Scroll down the page.
Thu Oct 22, 2009 1:26 pm
Post Re: carb buy
i looked down and didnt see anything
Thu Oct 22, 2009 10:42 pm
Post Re: carb buy
My bad - it's a carb you want and not a clutch.
Sorry about that.
Fri Oct 23, 2009 11:16 am
scooters and mods: 2008 ZUMA YW50
Post Re: carb buy
Have you considered just picking up a del orto 17.5 with elec choke. It's not ridiculous for a stock 50cc. Easy to tune, inexpensive option, that works like stock, but gives you some room to expand.
2001 ZUMAII - Tires TBD
Sat Oct 24, 2009 7:29 am
Post Re: carb buy
i have a stock one. pm me an offer.....
Sat Oct 24, 2009 11:00 pm
Users browsing this forum: Gregorypneup, VincentWen and 3 guests
