Register •
FAQ
• Search • Login
Page 1 of 1
[ 4 posts ] |
Author |
Message |
pbspecial
 55W H4 headlight bulb`
So I just bought a nice 2004 Zuma that will eventually go to my son at school. I took it for a ride last night and realized the headlight output is fair at best. I had a pair of Sylvania H4 bulbs in the tool box from an old snowmobile. Question is, can I install just one H4 55W bulb to use as the high beam without any charging issues. It seemed to work fine and threw much better light but been reading that the charging system is rather weak. Don't want to create any issues. Again, I would only use it in the high beam light and not run it dualed with low beam....
Thanks!
Tue Oct 03, 2017 7:15 am |
vettex2
 Re: 55W H4 headlight bulb`
I'd buy some LEDs. That are bright and won't tax the limited charging system
Tue Oct 03, 2017 1:47 pm |
jmkjr72
Joined: Thu Mar 20, 2008 5:27 pm Posts: 14825 Location: portage wi
First thing is the headlights are on a lighting circut and run right off the mag This is why they dim when you idle If you haven't done the dual headlight mod you a re running a single 35 watt bulb I've ridden 30000 plus rural miles with the dual headlight mod and standard bulbs 75 watts total Yes it will handle a single 55 watt bulb unlike many of the cheap China bike that have plastic light housing the zuma uses glass
I don't know how well the led headlamps will work with the non constant voltage as it drops at idle and increases with rpm
_________________ 2008 zuma dual headlight mod koso mirrors liquid cooled polini corsa kit leo vince zx stage 6 variator rally kit custom red paintFUEL INJECTEDsoon to be 100cc 2008 stella olive custom ported 177 cc kit dechromed ford tear drop tail light alive and breathing and awaiting cosmtic surgery thanks to an donkey hind quater hole cager 1985 elite 150 how long can i leave it stock
Tue Oct 03, 2017 3:41 pm |
vettex2
jmkjr72 wrote: I don't know how well the led headlamps will work with the non constant voltage as it drops at idle and increases with rpm
pretty good for me so far http://www.ebay.com/itm/15W-H4-LED-Ligh ... 9L&vxp=mtr
Wed Oct 04, 2017 9:51 am |
Page 1 of 1
[ 4 posts ] |
Who is online |
Users browsing this forum: No registered users and 4 guests |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
