Register •
FAQ
• Search • Login
Page 1 of 1
[ 3 posts ] |
Author |
Message |
IndianaBones
 Boss Amazon system.
Has anyone tried these? great reviews and price, wondering if it would draw too much power.... http://www.amazon.com/MC400-Motorcycle- ... e+speakers
Fri Feb 22, 2013 12:42 am |
IndianaBones
 Re: Boss Amazon system.
Fri Feb 22, 2013 12:46 am |
ZUMIKE
Joined: Fri Jun 25, 2010 6:56 am Posts: 14281 Location: San Diego, CA
which scooter do you have that will tell us how much extra power you have to run accessories
but I will go ahead and say if you have any of the zumas it will drain the battery on you really not much wattage left to power anything
you will probably have to run a dedicated battery for this, and charge it when your not riding the bike
if you want music you will probably be better off with an in helmet system unless that dedicated battery will last long enough between charges
2010 Zuma 155cc BWS X Digital Gauges<>Clear Smoke BWS 125 Turn Signal Covers<>Billet Bar Ends<>Front Brake Rotor 260mm<>Razor Cam Covers<>NCY Breather Assembly<>Polini EVO Clutch Bell<>Anodized Orange Dipstick<>RRGS Front and Rear Shocks<>Dual 5000K HID's 35w High/Low Beam<>Black Adjustable Brake levers<>Halo Led's<>TST 2 Stage Variator 9gL 10gS <>NCY Oil Cooler<>Yamaha Skid Plate<>NCY Contra Spring Bearing<>1000 Rpm RRGS Contra Spring<>Yoshimura Exhaust<>NCY Direct Ignition Coil<>Lightweight Cooling Fan<>Koso Cable Clamps<>High Lift Cam+Lightened Cam Sprocket<>Underseat Storage Bag<>Stage 6 (Koso) Clutch<>Accel Handlebars<>Koso Brake Light<>Lightweight Swingarm<>RRGS 4 Pot Caliper (PH80)<>Stainless Braided Brake Line<>Lightened F|ywheel<>OEM Headlight Screens<>Zubiku Wing<>Air Horn<>9 inch stretch<>Koso High Flow Filter/Cover<>RPM 10 Spoke Wheels<>Digital Camo Vinyl Wrap<>SEP Cvt Covers
Fri Feb 22, 2013 7:56 am |
Page 1 of 1
[ 3 posts ] |
Who is online |
Users browsing this forum: No registered users and 1 guest |
