View unanswered posts | View active topics It is currently Tue Mar 19, 2019 2:27 pm
Reply to topic  [ 7 posts ]
 Usb Charging Outlet help Needed!
scooters and mods: 2006 Blue Yamaha BWS, Blacked out rack, rims and fairing cover, stickers removed, triple-brakelight mod with all LED,
Post Usb Charging Outlet help Needed!
So I want to put one of the usb outlet things that run off the battery under my scooter seat (the cheap one in the thread: Battery tender < usb power outlet = very cool) and was going to add a fuse on the positivewire to keep it from destroying itself, so here's the question: what size fuse?
2006 Yamaha BWS Blue/Black
-Dual Headlight mod -Triple brake light mod with LEDS -Stebel TM 80 Magnum Low Tone horn
-black powdered coated rack and CVT cover -De-stickered -Frame/under mounted foot pegs with quick removable pegs -Angry Eyes
-Dr. Pulley 7.5G sliders -No engine mods...... yet
Sat Sep 14, 2013 7:47 pm
Post Re: Usb Charging Outlet help Needed!
since usb is such little wattage
I would go for 5 amp
as long as the wiring is rated for 5 amp or larger
but if your using a real battery tender pigtail they come with a fuse already on the wire
Sat Sep 14, 2013 8:14 pm
johnnyfyx will chime in here. he's already done a write up on this i think. but here is some food for thought.
viewtopic.php?f=54&t=17472&hilit=outlet
Sat Sep 14, 2013 8:24 pm
it only pulls one amp. I would throw a 5 amp in there.
Battery tender's come with a fused sae pigtail, and that has a 7.5a in it.
I would use whatever I had around, 3-8amps.
Sun Sep 15, 2013 5:13 am
So, i wanna charge my phone (1500 MaH) and my x-mini II speaker and ipod nano (400 MaH for the speaker, ipod i dont know about) would this be good enough?: http://www.ebay.com/itm/12V-Waterproof- ... 1194274395 and if not, could someone give me the link to a better one?
Sun Sep 15, 2013 3:28 pm
I don't see a fuse on that one...USB units will constantly draw power from ur battery...what type of scoot u got? A 50 or a 125? If its a 50 I'd be sure to have a battery tender handy!
Sun Sep 15, 2013 8:34 pm
2005 Blue/Black BWS, and yeah.. its got a battery tender
Mon Sep 16, 2013 12:28 pm
