View unanswered posts | View active topics It is currently Tue Feb 19, 2019 4:38 pm
This topic is locked, you cannot edit posts or make further replies.  [ 8 posts ]
 Electrical Question
scooters and mods: 2005 BWS50 Bugeye!! BZZzz
Post Electrical Question
Hi all....
I have just a simple question.. thanks in advance
Which wires do I tap into for adding some LED marker lights up front?
I see there's Brown and Grey on the harness as well as Black.... Do I use those?
Again Thank you
Wed Nov 06, 2013 3:16 am
Post Re: Electrical Question
up front for what
signals, running lights, lights only controlled off a switch?
Wed Nov 06, 2013 7:07 am
You should really start with what you're riding.
Do you want these ONLY to be """markers""" ??
or
would you like to use them as turn signals ??
Akshun wrote:
Which wires do I tap for adding LED marker lights up front?
The brown would be left, the grey for right, black is common to the both.
If you want the markers to be ON CONTINUOUSLY ... I'd say :: don't use the brown and grey at all.
You'd have to tell me which scoot that we're talking about
but
I'm gonna guess that you're looking at turn signal wires.
Wed Nov 06, 2013 12:13 pm
Oh sorry! Its a 2005 bws50
Yes just as like a marker light up front for more being more visible to oncoming traffic.
They are sort of like them LEDs on on the front of audis and mercedes cars
A switch might be a good idea too. I can put that in the glovebox
Thank you again
Wed Nov 06, 2013 12:42 pm
I'd hook them up brown.&.black for one, grey.&.black for the other
and use them as turn signals.
I don't know the electrics of the 2T. I'm kinda thinking that the SIGNALS ARE BATTERY // DC
so
your LEDs ... they'll work
Akshun wrote:
Oh sorry! It's a 2005 bws50
Yes as a marker light up front for being more visible to oncoming traffic.
My thinking :: since they are going to be so close to the headlight. If they cannot see the headlight ...
they're not going to see your markers, either.
Wed Nov 06, 2013 1:13 pm
so on with the bike
you need to find a 12v power source with the key on
may have a wire inside the headlight area where the ignition is you need to use a volt meter though
one is the rear tail light you can run a wire from that one, all the way up front
then it will come on with the key, and off with the key
Wed Nov 06, 2013 1:21 pm
Thank you for the information guys!! I shall get power from the rear light I'm guessing. I will post a pic when done
Thu Nov 07, 2013 1:49 pm
The horn should have switched 12V power at one of the terminals.
Sat Nov 16, 2013 8:56 am
