View unanswered posts | View active topics It is currently Fri Jan 18, 2019 3:42 am
Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
 Keyless ignition kits???
Post Re: Keyless ignition kits???
I would use an arduino board with a blutooth or wifi component and power would most likely be 5vdc.
Check out these solenoids
http://www.jameco.com/1/3/solenoid-actuator-12vdc
with a little research and soldering, you can have a wifi capable lock/starter for cheap.
Fri Dec 13, 2013 9:51 am
scooters and mods: 09Zuma125,simota a/f,c3 mirrors,red instrmt LED,Koso tail,LV Exhaust,Dr. P var,11g sliders,12t u/g,Polini Bell,Piolt SCs
Thanks for the input and links. I'll be checking this out for a project down the line. The keyless units are on the expensive side and the wiring will be a task, especially if I try to add a solenoid for the seat latch...and I need to consider power consumption etc. The idea has been planted...
Sun Dec 15, 2013 9:07 am
you can get a pager alarm with remote start for around $100 brad name spy5000m
I have one on my zuma but did not install the remote start yet
Thu Dec 19, 2013 9:07 am
if the power used it a worries see about adding a solar panel charger to the bike they use to be cheap but have not looked them up in a while
Sat Mar 14, 2015 8:59 pm
Solar panel?
I've pretty much abandoned this issue for now. It's pretty expensive and you still need to carry the key to lock it, to get gas and to open the seat. I was trying to get away from carrying the key. I'll have to wait for better technology to achieve my dream...
Sun Mar 15, 2015 10:47 am
NFC. Figure it out and tell us how to do it.
Sun Mar 15, 2015 11:58 am
And what just happened? Did anyone read the additional specs on Dynamo's T-Max??? KEYFOB for keyless running!!!! I should get a piece of that action. :doh:
viewtopic.php?f=68&t=26581#p351639
Mon Mar 16, 2015 7:14 pm
