View unanswered posts | View active topics It is currently Tue Feb 19, 2019 4:39 pm
Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
 Aftermarket Speedo's
Post Re: Aftermarket Speedo's
Nick Batzdorf wrote:
And wear big rings and big gold chains. I know, I know...
Ya you bet
Thu Feb 06, 2014 6:56 pm
Pig wrote:
Why would you want to mount one of these multifunction gauges to the stock Handle bars? Makes no sense, you gotta ditch the factory bars and switch to a motocross style bar.
Yeah, this is all in prep for my decision to go bare bars or not.
I like the cowling around the speedo, but I hate the stock 40mph max speedo.
if I change the bars, I will need to choose a speedo too.
decisions decisions....I am terrible at choosing.
Fri Feb 07, 2014 5:08 am
All bets are off if if you're changing handle bars, but if you do a search, someone put the Vapor inside his stock cowling. He cut out something to surround it and fill in the space to the edge of the plastic window.
Fri Feb 07, 2014 11:59 am
I am going with the vapor. I can keep my existing bars, and shroud that way. I am going to mount the vapor inside the original meter mounting space, and I will add custom indicator lights for high beam, and turn signals.
I am going to call Trail Tech and order one with the ext wire for the temp sensor. I will probably get the generic fork style.
Mounted Like this:
Mon Feb 10, 2014 6:19 am
