View unanswered posts | View active topics It is currently Sun May 26, 2019 12:31 am
Reply to topic  [ 10 posts ]
 Trail Tech Vapor - In the Dash
Post Trail Tech Vapor - In the Dash
My vapor was delivered. Its pretty slick. At first i thought it was tiny, then i did a quick test in the dash, and the fit will be awesome. Its going to leave me with plenty of room to wire in my other indicators, maybe a usb port too.
Ill be starting in on this tomorrow, so i will update this thread with pics tomorrow.
File comment: It will end up looking like this...kinda
Wed Feb 19, 2014 3:59 pm
Post Re: Trail Tech Vapor - In the Dash
This wasn't too hard at all. I traced the vapor onto a sheet of cardstock, and made a pattern. transferred the pattern and cut out the bulk of the 1/16" styrene sheet with a dremel. then used a dremel sanding drum and needle files to perfect the fit.
This is still a mock up, as I will add a couple indicators on the corners I think.
I will make the final one out of 1/8" styrene I think, its durable, and easy to work with , and the colors I have match.
Fri Feb 21, 2014 10:25 am
Fri Feb 21, 2014 11:47 am
scooters and mods: currently building.....
You finish it yet...post some pics.
2005 Zuma-MKII Race, MKII 21MM PHBG 40/92, C16, 12mm Crank, B9HS/LBO5EP 5K Cap, Advanced Timing, +1 Ignition Coil, Premix 32:1, Derestricted Intake, VF3's, MHR OverRange Complete, 27 grams, MHR Delta Clutch, MHR Wing Bell, Red Contra, Blue Springs, Torsion Controller, 15/50 upgears (SOON 14/42), Oversize Fan, Snork removed, Start Block Off Plate, Throttle Cable and Single Pull Tube, Dual Headlight Mod, Integrated Rear Signals, Boppers, Tach/Temp Gauge, kickstand.
I GOT MACHETES AND SWORDS FOR ALL YOU FAGGOTS THAT ROAR....Image
Sun Feb 23, 2014 5:40 am
Not yet. I have about four different zuma projects going on simultaniously. I'll have this done soon.
Sun Feb 23, 2014 6:11 am
I decided to go with a piece of 1/8 red acrylic. Instead of styrene. The styrene was a little too flexible. I ordered indicator leds to mount on the panel for the standard yamaha dummy lights, hi beam blue, oil-yellow and the single green turn signal.
Sun Mar 02, 2014 3:06 pm
Finished the guage. I ended up using opaque red acrylic for the faceplate. I fit three tiny LED indicators to replace the high beam, oil, and turn indicators. I will use black silicone to secure the vapor body into the frame (although it is a press fit, I just don't want any water seepage) as well as to attach the frame to the handlebar gauge cover.
File comment: Vapor + indicators
Wed Mar 05, 2014 7:04 am
here is the pattern I used to cut the faceplate. Note: this DOES fit a prebug, I do not know if it fit's the bugeye.
The inside will fit the vapor guage VERY tightly. I cut it out and then used needle files to perfect the fit.
This is a 1:1 pattern on 8.5x11 paper.
File comment: Vapor dash pattern
172.16.47.72_Scan_to_Desktop_03-05-2014_09-08-10.pdf [14.71 KiB]
Downloaded 166 times
Wed Mar 05, 2014 7:11 am
Did those LEDs wind up working nicely for you?
The job looks fantastic man! Nice work!
Wed Mar 05, 2014 2:44 pm
They wont be powered up for about a week yet, ...so lets hope.
Wed Mar 05, 2014 3:04 pm
