Why doesn't Yamaha do Dual headlights as OEM?
Author |
Message |
matt_a
Joined: Wed Jun 04, 2008 5:39 am Posts: 198 Location: Hanover, PA
scooters and mods: '05 Zuma (Black) mostly stock
I did the dual-headlight mod last night. Instead of buying a kit from ebay, I just followed the instructions posted by jdubbya and a few others (thanks guys). It was super easy and I did it with stuff I already had so it was FREE! Anyhow, this mod seems like a no-brainer. It's such an obvious safety advantage. You can see and be seen much better this way. Which begs the question: Why do you think Yamaha doesn't set it up to work this way from the factory? Does anyone know?
Fri Jun 06, 2008 5:21 am |
Waldog
Joined: Thu Apr 24, 2008 5:18 am Posts: 1164 Location: Orlando, FL
scooters and mods: 1998 Zuma (Stock) 2002 Zuma (Stock)
 Re: Why doesn't Yamaha do Dual headlights as OEM?
Beacause Confucius say... Man who tell one too many light bulb jokes soon burn out.
Fri Jun 06, 2008 5:26 am |
matt_a
Waldog wrote: Beacause Confucius say... Man who tell one too many light bulb jokes soon burn out.  *rimshot. lol
Fri Jun 06, 2008 5:31 am |
Psychedelic_Zuma
Joined: Sat Aug 18, 2007 5:23 pm Posts: 2679 Location: Troutman, NC
scooters and mods: 2008 Yamaha Zuma, Red, race driven.
There are a lot of things I don't understand about scooter/motorcycle/car manufacturers. This, the throttle restriction, and Subaru's retarded switch to a 2.5 L engine instead of using the 2.0 in the WRX.
_________________ Racer: 2008 Yamaha Zuma, basically stock. Daily Driver: 1991 Ford Ranger Turbo 2.3 RWD 5-Speed Pleasure/ Gas Sipper: 2009 Suzuki SFV650, stock (but not for long)
Fri Jun 06, 2008 2:05 pm |
Señor Don Gato
Joined: Wed Apr 02, 2008 11:57 am Posts: 946 Location: Harrisonburg, VA
scooters and mods: 03 Vino 70cc Ariasal T6, 19mm Arreche etc... 08 Ruckus Stock
I wondered this too. Honda made the Ruckus dual headlights which was very nice. But I don't understand the single light setup of the zuma.
_________________ Yo <3 Tortuga_Tomasa
Fri Jun 06, 2008 2:14 pm |
electroncraz91
Joined: Fri Aug 10, 2007 8:57 am Posts: 1024 Location: Northern Indiana
scooters and mods: 2000 Zuma-Bone Stock, 6000mi<, Homemade Alarm
Hope the 09's have dual headlights...
_________________ 2000 Zuma Bone Stock (6,260mi) 2001 Riva 125 Bone Stock (75mph) Scooter Gallery The Great Scooter Forum
Fri Jun 06, 2008 8:56 pm |
jmkjr72
Joined: Thu Mar 20, 2008 5:27 pm Posts: 14874 Location: portage wi
nope the 09 is the same one high one low
_________________ 2008 zuma dual headlight mod koso mirrors liquid cooled polini corsa kit leo vince zx stage 6 variator rally kit custom red paintFUEL INJECTEDsoon to be 100cc 2008 stella olive custom ported 177 cc kit dechromed ford tear drop tail light alive and breathing and awaiting cosmtic surgery thanks to an trump cager 1985 elite 150 how long can i leave it stock
Sat Jun 07, 2008 4:18 am |
Oldguy
Joined: Sun Apr 08, 2007 9:52 am Posts: 4484 Location: Austin, Texas
Because they want to give Zuma owners something to tinker with?
_________________ It is better to travel well than to arrive. The Buddha
Sat Jun 07, 2008 4:28 am |
electroncraz91
I should probably do a high beam mod on mine.
When the "high" switch is on, all it does is move the low beam at a higher angle. Four rectifying diodes should do the trick.
Sun Jun 08, 2008 10:16 am |
beeweeL
Joined: Wed Jun 11, 2008 12:48 pm Posts: 82 Location: Canada
Running both headlights tends to put a drain on the battery, if yamaha wired them together ppl would complain about their batteries running out (there are some ppl that would leave the ignition on without the engine running). The battery on a scooter is very small (all it really needs to do is run the starter) in order to keep weight down. So they could wire them together and include a larger battery but then ppl would complain about it weighing down their scoot and increasing the price of the scoot. Yamaha will get complaints for just about anything so they have to make decisions, like running only one light at a time, because that really is the best way to go about it. Now that's not to say wiring both together is a bad thing, only yamaha doesn't want to hear you complain about your battery not being good enough so learn to use your kickstarter for when your battery dies
Mon Jun 23, 2008 1:27 pm |
flapjacks
Zumaforums V.I.P.
Joined: Thu Oct 18, 2007 6:38 pm Posts: 3946 Location: Mohave Desert NW Arizona USA
Someone said its because the two headlights being on at once, would make drivers think they are seeing a car way off in the distance. Is this mod even street legal? I rarely ride at night, so the headlight mod to me is not needed anyways.
Mon Jun 23, 2008 2:48 pm |
Señor Don Gato
the rucks use the same size battery as zumas so I don't see why your battery dying would be a problem. When I turn my ignition to on my headlights don't come one and when the scooter is running the lights run off the motor(dont they?)
flap, I don't think the headlight mod would be illegal based on the ruckus's lights.
Mon Jun 23, 2008 3:15 pm |
beeweeL
Señor Don Gato wrote: the rucks use the same size battery as zumas so I don't see why your battery dying would be a problem. When I turn my ignition to on my headlights don't come one and when the scooter is running the lights run off the motor(dont they?)
flap, I don't think the headlight mod would be illegal based on the ruckus's lights. It normally wouldn't be a problem for the battery if you were riding it often and keeping a good charge in the battery but there are some ppl who don't ride them a lot and only go short distances, stop, run the starter, stop, run the starter. So there are ppl who could easily run the battery down. And yeah sorry i forgot the headlights do turn off with the ignition, my bad! But some ppls riding styles could wear down the battery pretty good. But anyway Yamaha's stance is that it has to do with the battery lol
Mon Jun 23, 2008 4:22 pm |
tomto
Joined: Mon Jul 28, 2008 6:04 am Posts: 41 Location: Montreal, Canada eh?
scooters and mods: 2005 bws, dual light mod
I contacted yamaha directly and asked them this question (thumbs up for the responce within a day) and their reason is: Quote: The output from the alternator is only enough to light one light at a time.If we put a larger alternator in the engine it would take away more engine power from the transmission, and reduce the speed. We use the two lights(instead of just one) for style.
Regards,
Scott stock altternator lights up both lights fine for me
Fri Aug 15, 2008 4:51 pm |
Psychedelic_Zuma
beeweeL wrote: Señor Don Gato wrote: the rucks use the same size battery as zumas so I don't see why your battery dying would be a problem. When I turn my ignition to on my headlights don't come one and when the scooter is running the lights run off the motor(dont they?)
flap, I don't think the headlight mod would be illegal based on the ruckus's lights. It normally wouldn't be a problem for the battery if you were riding it often and keeping a good charge in the battery but there are some ppl who don't ride them a lot and only go short distances, stop, run the starter, stop, run the starter. So there are ppl who could easily run the battery down. And yeah sorry i forgot the headlights do turn off with the ignition, my bad! But some ppls riding styles could wear down the battery pretty good. But anyway Yamaha's stance is that it has to do with the battery lol The headlights do not run off the battery.
Fri Aug 15, 2008 5:36 pm |
Who is online |
Users browsing this forum: No registered users and 1 guest |
