View unanswered posts | View active topics It is currently Fri Jan 18, 2019 3:22 am
Reply to topic  [ 9 posts ]
 Prebug Headlights- Best option for better bulbs/more light?
Post Prebug Headlights- Best option for better bulbs/more light?
Hello all,
Being a 3rd shifter, I actually use my headlights and care about how well they work. I've been searching high and low on here and all over the internet. I was hoping I'd be able to find a better/brighter bulb I could replace the stock bulbs with that'd make my prebug light up the night a little better.
I've looked at aftermarket items from BCD, but some folks say their bulbs are from track lighting and not made for weather or vibration. I NEED my lights to work no matter what, so I think the "quad optic" and other replacements might not be my best option. Or are they? Anybody out there have any aftermarket setups they like? I love the way my stock prebug looks, so I'd LIKE to just get better bulbs.
I found these: http://scootertuning.ca/en/lighting/400 ... d-35w.html
Any ideas that keep a mostly stock look and don't require tons of fabrication would be GREATLY appreciated. I just really want to be able to switch to better bulbs and have better lighting, but I've yet to stumble upon any useful info on this yet.
Thanks for any help you can offer!! :patriot: :cheers:
2000 Zuma 50: Bone stock... For now.
2009 Zuma 50: Soon to be back on the road...
Fri Jul 03, 2015 3:42 pm
Post Re: Prebug Headlights- Best option for better bulbs/more lig
Corrosion found these to be pretty good. I'll be switching to them myself.
Read this thread:
viewtopic.php?f=39&t=26244
2008 Zuma 50
2012 Zuma 50 (sold)
2003 Derbi Red Bullet
Fri Jul 03, 2015 3:59 pm
Thanks, Spaz! That's a really great write-ups!
My only concern would be that this thread deals with a bugeye, like my 2009, but I'm wanting something for my 2000 prebug...
Do you know if these bulbs would work for my 2000?
Fri Jul 03, 2015 5:05 pm
I don't know. Sorry.
Although you could see if the part numbers (bulbs) are the same between the two??
2008 Zuma 50
2012 Zuma 50 (sold)
Fri Jul 03, 2015 5:16 pm
My service manual only states that the bulbs for my 2000 are: "12V 25W/25 W x 2" That's exactly how it's written in the manual.
Are these the same bulbs as the bugeye?
Fri Jul 03, 2015 5:29 pm
Looks to be completely different. Like your bulbs are, part of/built into, the lens??
2000:
2005-2011:
Link for 2000:
http://www.yamahapart.com/oemparts/a/ya ... /headlight
Maybe speclk will have the answer for you??
2008 Zuma 50
2012 Zuma 50 (sold)
Fri Jul 03, 2015 5:58 pm
Thanks for pointing that out with the schematics. I did the dual headlight mod on my '09, so I remember what the bulbs looked like, but I've never had the front off my prebug to see them. I figured there'd be a ton of folks who've replaced the prebug's bulbs with something more adequate!
Man, I hope I can get some better lights though! I'm crafty, but when it comes the electrical, I might as well be reading braile...
Fri Jul 03, 2015 6:22 pm
Lights are simple though... two to three wires. One ground. one positive. and another positive if you have high beams. Easy peasy :)
2008 Zuma 50
2012 Zuma 50 (sold)
Fri Jul 03, 2015 6:30 pm
If the headlights are sealed units, then you won't be able to replace the bulbs alone. But you could modify them so they could accept H4-style bulbs. I'm planning on doing exactly that with my Jog headlight: cut out the old bulb area, cut out the bulb area off a broken bugeye headlight assembly, then epoxy it on the Jog headlight.
Those halogen bulbs like the ones you linked SUCKS for lights. They're house units with no focus whatsoever. They throw light around... and that's about it really.
Thu Mar 24, 2016 4:36 am
Users browsing this forum: Google [Bot] and 1 guest
