View unanswered posts | View active topics It is currently Sun May 26, 2019 12:42 pm
 What are the cluster bulbs for a Bugeye 50?
scooters and mods: Zuma 70cc Athena
Post What are the cluster bulbs for a Bugeye 50?
I've been trying to search this for the past half hour and can't find anything solid. Are they 194's? I have one scoot that the backlighting of the gauge doesn't light up like it should. The turn signal and high beam work as they should so I don't think it's a connector unplugged, but I can check. Just want to see if I can get replacement locally before digging into it to see what bulb they are.
2005 Yamaha Zuma Athena 70cc, Midnight Black, stock exhaust, 82 MJ, Michelin Bopper tires, NCY 107mm performance clutch & NCY performance clutch bell, Athena 15/50 helicals // "LEROY"
2005 Yamaha Zuma Athena 70cc, Midnight Black, stock exhaust 84 Main Jet, // the $250 scoot, with 23,000 miles!
2008 Yamaha Zuma, Blue Metallic, Athena 70 sport, Leo Vince ZX-R (soon to be installed), Dellorto 19mm, Stage 6 choke
Mon Oct 26, 2015 8:33 am
Post Re: What are the cluster bulbs for a Bugeye 50?
They look just like these. The link says Mercedes, but those bulbs are used in lots of applications.
http://www.amazon.com/Mercedes-OSRAM-In ... B009PXE0AO
2008 Zuma 50
2012 Zuma 50 (sold)
2003 Derbi Red Bullet
Mon Oct 26, 2015 7:17 pm
Got some from the store, but realize that the old ones had little green covers on them. I'd like to find those again because they were melted on these old bulbs. Wonder what official part I need to get from Yamaha to get those
Tue Nov 03, 2015 8:17 am
