View unanswered posts | View active topics It is currently Sat Feb 16, 2019 7:02 am
This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Recent headlight issues...
Post Recent headlight issues...
I have an '02 Zuma that's pretty much stock but I have done the dual headlight mod and also have gotten the JDM tail light put on it. Last night I went riding a bit and then my headlights suddenly stopped working for a few seconds and then they came back on. The second time it happened and I tried switching to high beams and there was still no light coming out. I was more concerned about getting home without any trouble and I didn't get a chance to see if it had effected the tail light also. I rode up the street to see if it would happen again to try and check the tail light but they didn't turn off again.
Anyone else have a similar issue like this before? I'm not sure what would cause them to turn off for a short time but I'd like to fix it before it happens again and they don't come back on.
Sun Jul 03, 2016 5:46 am
Post Re: Recent headlight issues...
your headlights are powered off ac power off the stator, only works when engine is running
your brake lights, signal, horn if off the dc battery power, works with the key in the on position
my guess is your dual light wiring or sockets on the bulbs came loose for a second and cut out
maybe check for corrosion too
Sun Jul 03, 2016 9:22 am
Ok I'll try checking that out soon, thank you.
Mon Jul 04, 2016 8:36 am
