View unanswered posts | View active topics It is currently Mon Sep 24, 2018 4:54 am
This topic is locked, you cannot edit posts or make further replies.  [ 7 posts ]
 Headlight bulb rotation?
Post Headlight bulb rotation?
Do H4 bulbs need to be installed at a certain rotation, like the top of the three tabs pointing directly up. I put in dual headlight wiring and 45w bulbs but not sure I got them directly rotated the same in the rubber cups.
2014 Zuma 125
Sat Aug 20, 2016 4:17 pm
Post Re: Headlight bulb rotation?
h4 has 3 prongs on the bulb base
they will only fit one way into a h4 headlight
so its kinda hard to install wrong
unless your not using h4 bulbs
Sat Aug 20, 2016 8:28 pm
Ya they are three prong and seem ok they are just not perfectly aligned with the top tap pointing straight up. They are rotated a little so the top tab is at 1:00 instead of 12:00 so to speak.
2014 Zuma 125
Sat Aug 20, 2016 8:35 pm
most h4 lights I work on (as I take them apart and install halo light rings in them)
its not set at 12oclock straight up
they are off to the side a touch. or twisted
the molding in the headlight lens itself
if that makes sense
I think the factory has figured the best light pattern if the bulb is clocked to the side a touch
is this what your referring too?
or are you saying your actual h4 bulbs tabs are too thin and it causes the bulb to sit crooked?
later I may be able to get some pics to show what im trying to describe
Sun Aug 21, 2016 8:31 am
h4 lights off 2 different bikes
you can see they both twist the bulb slightly from level
Sun Aug 21, 2016 12:42 pm
Very interesting, thanks. So I guess its just trial and error.
2014 Zuma 125
Thu Aug 25, 2016 11:39 am
whats trial and error?
the bulb only installs one way
you look at the tabs, spin the bulb until the tabs line up and it drops in
Thu Aug 25, 2016 3:10 pm
