View unanswered posts | View active topics It is currently Sun Apr 22, 2018 12:54 pm
Reply to topic  [ 8 posts ]
 Whats the best exhaust pipe for a stock 50cc and how to tune
Post Whats the best exhaust pipe for a stock 50cc and how to tune
So im thinking that I want to get a new aftermarket exhaust pipe for my stock 50cc zuma. I would like a little more top-end speed without losing low-end power. Anyone have experience with a any pipes that theyve put onto their moped? How did the pipe effect the power, better high-end? better low end power? And did you have to do anything else to get the moped to run well with the new pipe?
2005 Yamaha Zuma YW50T,
Dual headlight mod
Tue Mar 09, 2010 8:49 pm
Post Re: Whats the best exhaust pipe for a stock 50cc and how to tune
look around a little. you will find your answer. i like my sp3. u will have to do some tuning, and if u have a '08 to '10 you'll have to take the smog box off and plug the hole in the airbox
'06 vino125 55mph 85mpg
'08 zuma50 53mph 65mpg
Wed Mar 10, 2010 5:14 am
1. you should get plenty of ideas and input around here.
2. IT'S NOT A MOPED! THOSE HAVE PEDALS. IT'S A SCOOTER.
Wed Mar 10, 2010 5:32 am
Yeah, you should do some digging around this site: People have posted lots about exhausts on here. The most commonly used pipe is the Leo Vince ZX or SP3.
Most of the time when you add a performance exhaust, you will need to adjust your clutch springs and roller weights to tune your scoot in the exhausts power band.
Wed Mar 10, 2010 7:52 am
I really enjoyed my Leo Vince ZX. I ran it for over 8,000 miles before I did a big bore upgrade with new pipe. Leo Vince also include springs and weights that are easy to install and necessary for the pipe to perform in its power band.
2005 Yamaha Zuma 50
58 mph (GPS)
0-40mph ?? Seconds
Malossi Sport 70cc BBK - Stage6 PRO Exhaust - Dellorto PHVA 17.5mm 92MJ, 34Idle, A12 Needle Up One Position, Snorkel Removed - Athena Primary Drive Gear - Nology Hotwire - Malossi Reed Cage - Malossi Multivar - Stage6 Rollers 30g - Malossi Delta Clutch - Malossi Wing Clutch Bell - Malossi Torsion Controller - Malossi Yellow Contra - Motoforce Racing R6 Rear Shock - Slipstreamer Windshield - Dual Headlight - Triple Brake light - EMGO Trunk - Ram-Mount for GPS
Wed Mar 10, 2010 8:02 am
Tecnigas Next R is a screamer. You will get good topend and you won't bottom, especially off of the stock pipe. The ZX is a good pipe too, but will mostly just boost torque, IMO and experience.
2001 ZUMAII - Tires TBD
Wed Mar 10, 2010 12:19 pm
Well after doing much research, i decided to go with the SP3. I ordered it last week off of ebay and it just came in the mail today. i just grinded off the restrictor cone tonight and tomorrow I will be fitting on the new SP3 pipe to my zuma 50 along with the new clutch weights that it came with. Ill post another one explaining how the pipe and weights perform compared to the stock exhaust.
Dual headlight mod
Tue Mar 16, 2010 9:15 pm
you wont be dissapointed. the sp3 rocks. and those are wweights for the variator not the clutch. let us no what you think. it felt like a whole new bike after installing mine. i gained almost 3-4 mph.
00 ZUMA
front turn signals relocated
Pirelli SL26
LV SP3
Malossi 70cc cast iron kit
Malossi front brake pads and rear shoes
Malossi variator
Malossi delta clutch
Wed Mar 17, 2010 7:08 am
