View unanswered posts | View active topics It is currently Thu Apr 25, 2019 11:22 pm
Reply to topic  [ 8 posts ]
 WI - HI IM NEW AND GOT A ZUMA50 2005
scooters and mods: 2005 Zuma 50 Athena muffler, dual headlights are only mods
Post WI - HI IM NEW AND GOT A ZUMA50 2005
Hey everyone! Just picked up a 2005 Zuma 50. Nothing has been modded on it except the exhaust. It says Athena on the side. Zuma runs out about 42-43mph. Sometimes it will get up there quick, other times it will take forever to get there. It's got 1950 mi. on it. Any suggestions where to start to keep it fast, reliable, and last a long time?
Mon May 07, 2018 9:28 pm
Post Re: Newb with a 2005 and questions
Hell if I still lived out by Harpts lake I would say bring it over but I live near the dells now
First start with a good once over of the bike any rubber product tire belt hoses that’s more then 5byears old should be replaced if you don’t know replace it
Belt only use genuine oem Yamaha belt
Change the plunge every 3000 miles as well as the trans oil 1/2 cup is all it takes
Tue May 08, 2018 6:05 am
scooters and mods: 2002 prebug (Canadian) stock
There’s also a really good “how too” thread about servicing the clutch pulley and bearings. Highly recommend doing it and it’s really very easy
Prebug
Giannelli extra exhaust, 98 main jet, 1500rpm clutch springs, 2000rpm contra, 5g rollers, carbon reeds
Wed May 09, 2018 3:28 am
scooters and mods: '03 yellow Zuma with Malossi 70 cc, rejetted stock carb and stock exhaust.
I highly recommend a Malossi cast iron 70cc cylinder. I have over 13 thousand miles on mine. I would think that whoever put the exhaust on compensated with either a rejet or different carb but I would check.
Enjoy!
Malossi 70cc, 82 main, 46 pilot and needle raised on stock carb, stock exhaust, air cleaner and clutch.
Wed May 09, 2018 8:45 am
Post Re: WI - HI IM NEW AND GOT A ZUMA50 2005
Hello, my wife and I will be getting one, the same year as yours. I can't wait to ride it around.
Sat May 19, 2018 1:06 pm
scooters and mods: 2006 BWS 50 (mods unknown), 2007 Piaggio mp3 250 (stock)
Just got a 2006 BWS / Zuma (I'm in Canada) and it has a LeoVince exhaust on it. PO tells me that it will take him steadily at 45mph and he's 6'4" and 260 lb. Is there a way to find out if the PO before him did a big bore kit on it? I'm bringing it home Friday and figure to look at the belt and see if the variator has been swapped out or whether the rollers have been changed out for Dr Pulleys. But don't know how (or if) I can see if there's been a cylinder upgrade.
My other question right now is what kind of % grade can I expect this to handle at 30mph carrying a 140 lb rider (me) and how long before it bogs down? Will determine how I get it home! Drive the RV with the motorcyle hitch carrier or ride it the 1 mile up a 7% grade in traffic :)
Thanks. Looking forward to this.
Tue Aug 14, 2018 5:25 pm
Hi neighbor
I have a newly purchased 2004 zuma . with about 2500 miles on it and 2 vinos with 2000 miles on them .
The vinos i just derestricted exhaust and variator and upjetted the carbs.
I have just started to modify the zuma .
MY first bit of advice go through the routine maintainance list and make sure that your zuma is right .
Al 3 of my scoots really need a good once over .
The gear oil in all 3 was really ugly.
Just installed dual headlight mod on zuma .
For performance I have decided to go exhaust /Carb Upjet and then rebalnce the variator if needed to exhaust.
Have a malossi wild lion exhaust on the way.
Winter Project /Late fall project is a BBK .
Have not decided which one yet.
2004 Vinos Derestricted exhaust and variator stock carb with mikuni 75 main jet needle down 1 clip 40 mph
2004 Zuma Malossi sport 70 cc breaking in with stock pipe then Technigas next r polini 107 mm clutch polini green springs high speed variator 84 main jet 46 pilot jet needle 1 clip rich
2005 eton beamer airsal sport 70cc 9200 peak rpm top speed 40 77.5 mikuni jet needle 1 clip rich
BBKs all around on the way
Sat Sep 08, 2018 8:54 pm
Welcome to the community!
Sun Sep 09, 2018 9:41 pm
