View unanswered posts | View active topics It is currently Sat Aug 24, 2019 6:00 pm
 Hey
Post Hey
Why hello everyone I hope all is well, so I was watching some videos on zuma tuning so on so forth, and chatting up with some knowledgeable people. I will bbk my 04 zuma in the future, right now I am thinking yasuni pipe and 1500 rpm contra and yellow clutch springs; my question I know a stocker can't rev that high, will the stiffer springs even help me gain any mph. I have been talking to people and they say it is a great way to go, but I was watching a video on a seller's web site and they seem to have added a variotor also to this adly. I am hitting 32mph on flats stock everything and bopper tires, want more umph but reliability on this bike is a must. Or will I also need a new variator too basically. Sorry my grammar is terribad.....
04 Yamaha zuma
ncy ramp plate Plus secondary pulley ( does alot )
Yasuni R derestricted + Carb Mod
Stock air-box, carb, and cylinder
Gates Long belt 44mph Gps'd
Mon Oct 29, 2018 9:40 pm
Post Re: Hey
I also have a 2004 .
Stock when i bought i would touch 39.
Cleaning carb changing gear oil pumping up tires to proper inflation.
I started to creep to 41mph .
Then slapped a low reving pipe wild lion pipe it helps low end acceleration more than top end .
With that pipe I left cvt alone .
I now hit 43 on a good day wind free day on flats .
Bbk is my winter project .
I looked at the yasuni r and z and i may still get one of those for more top end .
The current stock cylinder may limit the full out put of the pipe but you should still see a few mph because it will rev higher.
When you upgrade to a bbk the pipe and bbk will be a closer match to rpm max and you should see further acceleration and top end .
Just do one piece at a time either bbk or pipe and enjoy the results go slower on the variator and springs .
You will eventually need rollers or slider to balance the cvt to let it rev closer to where band of pipe and cylinder.
The clutch springs let you rev higher before the clutch bites helping with take off does nothing for top end .
Tue Oct 30, 2018 6:15 am
Post Re: Hey
Thanks for the info I am currently gonna grab the yasuni r and contra springs and clutch springs and the bbk, gonna install pipe and sliders Dr pully 5g and contra first though and ride it for a few weeks, Kit it around my bday when It is feb and chicago is a frozen desert; unless its warm this year then I'l do it over xmas break. Thanks again
04 Yamaha zuma
Thu Nov 01, 2018 7:01 pm
Users browsing this forum: Egoizmsek, qpidnetworktfu and 1 guest
