View unanswered posts | View active topics It is currently Tue Jul 16, 2019 11:42 am
 Choke cable/airbox for 2000/02 Zuma 2 stroke
Post Choke cable/airbox for 2000/02 Zuma 2 stroke
Hello everyone,
I just recently purchased a zuma 49cc 2-stroke and the model of the scooter is either made in 2002 or 2000.
On the shaft below the handle bars it says 02/2000 so Im assuming it's between that time frame or one or the other.
I've seen a ton of different sites selling choke cables for these, and i've also seen posts on here which say to avoid certain sites. I want to make sure I can get this cable ordered so It will fit the little lever for the choke for your thumb below the left handle. I want to get riding asap and need to have someone direct me to the best parts website.
I just took the moped to a shop where the shop owner used a "master key" to start the moped since there isn't a key for it. She started right up without starter fluid with 2 yr old gas and oil haha. Compression test was good, brakes are good, carb is decently clean, and the shop owner said I made a really really good purchase since these 2-strokes are pretty fast compared to the new models.
So I'm either going to have to get a new key made or buy a new key/lock ignition assembly for it as well. The shop owner quoted me an absolutely ridiculous price of $522+tax to put the all the parts on for me..... I promptly left and I'm doing this myself now. He wouldn't tell me where he orders his parts from since i used his time to check it out.....
For this project I basically need to build a seat, find a working key or a new ignition setup, and get the choke cable/airbox.
The previous owner of the moped "inherited it" when a former tenant left it for dead at his rental house. He assumed it didn't run and proceeded to sell off the air box, seat, rear frame/brake lights, choke cable, engine cover and battery for parts lol. Just because its been sitting outside for 2 years and didn't have a key doesn't mean it doesn't run!!
If you know of any direct links for parts for a 2000-02 zuma, or a parts website which is reliable please let me know! Thanks for the help!!
In summary, Im looking for:
a new choke cable
a new air box and/or clamp on air filter to go on the air intake of the carb.
a replacement key and or ignition for the scooter.
Tue Nov 27, 2018 8:15 am
Post Re: Choke cable/airbox for 2000/02 Zuma 2 stroke
Welcome to the forums
That is a 2000 it is a prebug zuma
That is too much for something you can do yourself .
The parts you are looking for are oem .
Here is what I do look up part I need on bike bandit or yamaha warehouse to get a idea of cost and then just order them if they are in reason from my local yamaha dealer.
They have matched prices or come very close with free shipping.
I have bought from zumasrus, drowsports , scooterpartsco ,scootertuning.ca for various aftermarket parts they all have taken very good care of me with multiple orders .
You may be able to get some help from them also on some of those parts .
You also could post on the forums here and ask for the parts .
2004 Zuma Malossi sport 70 cc Technigas next r 2008 zuma torque driver polini high speed variator 5.5 grams sliders malossi delta clutch yellow contra yellow clutch springs Stock Carb 82 main jet 46 pilot jet needle 1 clip rich stock athena 14/42 gears 11 to 1 final ratio 56 mph
Tue Nov 27, 2018 6:03 pm
wow its really intresting post.
If you need write technical cv its a easy can there. Its really good chance for search your job.
Fri Nov 30, 2018 9:05 am
