View unanswered posts | View active topics It is currently Sun Apr 22, 2018 12:47 pm
Reply to topic  [ 19 posts ]  Go to page 1, 2  Next
 How many miles will a Zuma get before dying?
Post How many miles will a Zuma get before dying?
To start, hello all, I'm considering getting a Zuma to have a practical vehicle to save gas with to get from place to place around town and to and from work (I work a mile away, everywhere else I go is close as well) and I was wondering, how many miles will this scooter get before going down the drain?
Wed May 18, 2011 5:10 am
Post Re: How many miles will a Zuma get before dying?
11500 miles + viewtopic.php?f=55&t=16183
Life expectancy of Zuma viewtopic.php?f=47&t=14867&hilit=+will+last
Nobody has worn out a chassis and engine case yet, so its anybodies guess :confused:
Wed May 18, 2011 6:14 am
Thanks for the response guy! however, looking at the links you gave me, I'm seeing alot of 30-50k claims by them, they're riding 125 I beleive, is it that much a difference, 11.5k to 30k amping up to 125cc? Is the motor that weak on the 49cc? Realistically I'm looking into a 49cc for the mpg and the lack of necessity in a motorcycle license, however, would it be better if I spent the 100 or w/e it costs to get a different license and amp up the CC? Does 125cc cost significantly more than 49cc? Sorry for all the questions, but you seemed rather specific on the lifetime of the 49cc model, just tryinta make sure it's worth it, y'know?
Wed May 18, 2011 6:21 am
Go to the official Yamaha home page, you can find all the specifics there. MPG, cost, and features. Don't let anybody influence your decision. Its your scoot, tailor it to your needs. Just don't have false expectations such as getting MPG and MPH. You can't have both. Hope this helps.
Wed May 18, 2011 6:42 am
It isn't the size of the motor that makes the difference. The 50cc is a two-stroke and the 125cc a four-stroke. The 125 is faster and gets better gas mileage, but requires more maintenance. Oil changes, valve adjustments etc. Of course the 125 costs more as well. Depending on what state you live in the 125 may require a motorcycle license while the 50 may just require a moped license or possibly none at all.
It is better to travel well than to arrive.
The Buddha
Wed May 18, 2011 7:29 am
At least in my area:
brand new z50 = $2400
brand new z125 = $3200
Then, factor in monthly insurance. I think the 50 is usually the better investment overall. You have plenty of options open to you for modifications that will get plenty of speed, that will probably cost less than a 125. All the moreso less if you get a used 50 in good shape.
As for the life span of the z50, the same basic concepts apply. Take care of it, keep it well maintained, and it'll last you a long time.
09 Zuma
Dual Headlights
C3 mirrors
JDM taillights
Tmod
Derestricted exhaust
Leo Vince ZX chrome
Wed May 18, 2011 8:37 am
yep im still tortureing mine at over 10,000 miles about 4000 of that has been moded
and i just started with a fresh top end and will go a full season without doing anything other then basic maintnace to it
trans oil air filter spark plug i will be do for new front brakes in about another 3000 miles and tires in about the same
Wed May 18, 2011 4:43 pm
dont believe that 123 mpg for the 50. i dont think i ever got better that 80 mpg stock. the c3 will get that kind of milage though
'06 vino125 55mph 85mpg
'08 zuma50 53mph 65mpg
Wed May 18, 2011 5:32 pm
I've owned both the 50 and the 125 for my 3 mile commute and general traveling around. Within months of having the 50, and as much fun as it is, I was looking to upgrade. I got the 125 about 15 months after the original purchase. My brand new 2009 Z125 in September 2010 was $2,450 OTD.
I think gas prices were going down at that time, sales were slowing for the 2009 and the 2011s were about ready to come out, so Yamaha put a $500 rebate on the 2009 125.
I keep the engine stock and I've never looked back. I like the fact that I can now go on the interstate for short stints and I can take it on longer trips on the group rides without holding everyone else to 40 mph.
2009 Zuma 125 picked up 9/21/2010 with 9/10 of a mile on the odo
C3 Mirrors, GPS Ram-Mount, Stebel M80 Magnum low tone horn,
KS/BTX Forward Pegs, Rear Rack with GIVI trunk
Clocks4Bikes Handlebar Clock, Termoscud Lap Apron (seasonal)
VA Tag: 96 MPG
Rolling Thunder/Ride of the Patriots 2012
Rolling Thunder/Ride of the Patriots 2011
Member # 1807
http://www.facebook.com/steven.levine1?ref=name
Gone, but not forgotten:
2008 Zuma 50--FAREWELL PARTY-SEPTEMBER 30, 2010
Co-SOTM November 2009
Rolling Thunder/Ride of the Patriots 2010
Wed May 18, 2011 6:39 pm
I bought my '03 Zuma used, and it was an abused stage 1 (do not know at what mileage P/O upgraded), but the odo read 15,XXX miles plus before I started modding. Piston/cylinder still had more life in them too!
'04 Vino Dull Metallic Red=Doppler Endurance, S6 MKI Sport Pro, Dellorto 21mm PHBG, S6 Pro Rep, 17/44 Malossi upgears, Malossi multivar, S6 MKII clutch, RRGS drag forks w/composimo lowering springs, Daytona 8hole rims, Brembo P32, KN 190mm wave rotor
'03 Zuma Vivid Yellow returned to stock, Leo Vince ZX, '08 gears
'07 White Camo Z50 swapped Ruck=Motoforce Evolution c/s, S6 MKII Sport Pro, Dellorto 19mm PHBG, Polini 45* intake manifold, S6 V-Force reedcage, Yasuni C-16, Malossi multivar, S6 MKII clutch, S6 bell, 14/42 Athena upgears
Wed May 18, 2011 11:15 pm
My 06 has 14K on the odo and 17K when i put in my 70cc kit.
the stock cylinder and piston looked fine when i took it out. it still had ALOT of life out of it. at least 10 000kms.
Fri May 20, 2011 5:30 pm
My '05 50cc has 35k+ miles w/a new top end....I'm hoping to get 15k more :cheers:
Tue Jul 19, 2011 9:20 pm
mine has 16000 and just died w no matience there hard scoots there the best out there and its a 50cc
Tue Aug 09, 2011 9:14 pm
My 2001 had 31,000kms on it. Shocks were okay but worn. Everything was great! And everything worked, got 75km/h with a leovince TT and rollers.
Fri Aug 12, 2011 7:21 pm
75 on just a pipe? i find that a little tough to believe, im geting 70 with a bbk.
did you get a chance to mail the pipe out today?
Zuma 50 - Gone! -link-
Pocket bike, Giovanni f1 & x1 mid bike -link-
Ruckus - In da garage! -link-
Fri Aug 12, 2011 7:23 pm
