View unanswered posts | View active topics It is currently Sun May 20, 2018 8:24 am
 Need some help here!
Post Need some help here!
ok, so im about to start ordering all my parts for my crank mod for an 02 vino 2t. list of mods i have already, athena 70cc alumi. cylinder kit, 17.5 Dellorto carb, polini CF reeds, YTR Foam filter, Gianelli Silencer "SHOT" pipe, Malossi Torque spring (red), Malossi Delta clutch w/winged bell, polini variator 6roller. parts im about to order include, stage6 hpc 10mm crank, stage6 metal cage crank bearing, malossi delta race clutch springs (red). im collecting all tools required for this mod, and reseached about doing this mod (thanks hya for the awsome write up) so here are my questions
#1 im gonna order a s6 main jet kit to tune, not sure which one i should go with? any ideas!? i live in southern california about 200 feet above sea level.
#2 should i start to premix with this setup and at what ratio!?
..... my gianelli pipe allowed my previsous 70cc (s6 pro sport) kit to rev up to 12k or so, and destroyed my s6 kit and crank. thats why im upgrading my crank
:cheers:
c-kell wrote:
''The Thrilla Of The Villa""
2002 Yamaha Vino Classic S
Engine mods:
Motoforce Evo crank Stage 6 Streetrace kit Dellorto 17.5 man choke
Polini carbon fiber reeds. Gianelli shot exhaust
CVT mods:
Polini Variator. Hebo Driveface. Malossi Winged Clutch Bell. Stage 6 clutch springs
Suspension:
RDR Nitrogen Filled Shock (rear)
Frame:
Home fabricated 6" stretch 2" lower
ZF member #14
Wed Jul 08, 2009 6:34 pm
Post Re: Need some help here!
molefb wrote:
ok, so im about to start ordering all my parts for my crank mod for an 02 vino 2t. list of mods i have already, athena 70cc alumi. cylinder kit, 17.5 Dellorto carb, polini CF reeds, YTR Foam filter, Gianelli Silencer "SHOT" pipe, Malossi Torque spring (red), Malossi Delta clutch w/winged bell, polini variator 6roller. parts im about to order include, stage6 hpc 10mm crankThat crank is PIMPIN! Be carful not to scratch it up during your install., stage6 metal cage crank bearing Bad idea, you should get the SKF bearings from Athena. I'd have to check those ones to be sure they are ok. DO NOT FORGET TO REPLACE YOUR CRANK SEALS! or you will be doing it all over again., malossi delta race clutch springs (red). im collecting all tools required for this mod, and reseached about doing this mod (thanks hya for the awsome write upBoom Shaka Laka!) so here are my questions
#1 im gonna order a s6 main jet kit to tune, not sure which one i should go with? any ideas!Get the one that maxes out at 110 and has a minimum 85 jet.? i live in southern california about 200 feet above sea level.Lucky bastage! I would kill to live there.
#2 should i start to premix with this setup and at what ratio!? 25:1 Better just remove all that oil stuff while you are in there. Leave the teflon gear on and just pull the little sprocket off the oil pump and put the pump back where you found it.
..... my gianelli pipe allowed my previsous 70cc (s6 pro sport) kit to rev up to 12k or so, and destroyed my s6 kit and crankThat stinks!. thats why im upgrading my crank
:cheers:
Hyazuma
Current Configuration:
3. NGK BR7HS
6. Malossi Delta Clutch
9. Malossi Up-Gears
13. Arreche 19mm Carburetor
14. Arreche Manual Choke
Thu Jul 09, 2009 9:51 pm
