View unanswered posts | View active topics It is currently Fri Feb 15, 2019 2:45 pm
Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3, 4
 stage6 crank swap!!
scooters and mods: 96 Jog 05 Vino 08 C3 04 Super 9 00 SR
Post Re: stage6 crank swap!!
I believe we have seen others here get mid 60's with those gears on a Vino.
Mon Jul 11, 2011 9:28 pm
scooters and mods: 2004 Zuma Grey, Polini cast iron sport 70, 6g rollers, stage 6 clutch bell, adige 3 shoe 107mm clutch, Michelin regge...
molefb wrote:
thanks hya for the info on factory pro cv carb tuning, i studied it like a book...
here are those pics i been promising.
How did you do the case paint
04 Yamaha Zuma 9***mi
UNDER CONSTRUCTION....Polini Sport 70(25**mi+),Stock Crank,Adige 3 Shoe 107MM Clutch, Stage6 r/t 107mm bell, highway bars, 6G Malossi Rollers, Kevlar Belt( had two left over) , 19mm Dellorto PHBG Race Carb W/ S6 Choke, Polini Team 3 Exhaust, Uni Filter(Stock Air Box Snorkel Removed), Cf Reeds(Stock cage), Regge Tires, Black 05 Rims, EBC Breaks F/R,Duel Headlight, R Fender Downsize...Add & Fix As I Go....Need Help Please,Anyone & Local MI Area Would Be Good
Winter14/spring15 project for 04 zuma- s6 or polini crank, bigger better better top end Still deciding, and go from there... crank case paint? New hoses wiring every piece top to bottom
WTB: 88-2000 PREBUG
05 Yamaha Zuma R.I.P-Had Good Times
Fri Aug 01, 2014 7:47 pm
