View unanswered posts | View active topics It is currently Fri Jan 18, 2019 9:43 pm
Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3, 4  Next
 stage6 crank swap!!
Post Re: stage6 crank swap!!
Please post your pictures as attachments so we can see the blown up view. That will make this write up that much more helpful for future members.
Thank you for your cool updates!
Hya
Current Configuration:
3. NGK BR7HS
6. Malossi Delta Clutch
9. Malossi Up-Gears
13. Arreche 19mm Carburetor
14. Arreche Manual Choke
Sun Jul 26, 2009 12:02 am
Hows the install coming along?
Hyazuma
3. NGK BR7HS
9. Malossi Up-Gears
Mon Jul 27, 2009 12:49 pm
scooters and mods: *2002 yamaha vino classic*
waiting for my bearing to arrive on my door steps. I ordered the malossi bearing from provoscooter on friday. Everyone else had them on backorder. So far the case's are painted flat black along with the transmission case cover. I really want to get my scooter up and running already so i can start tuning. And clean her up and wax the paint. Get my baby looking pimp so i can go on some night rides with some rucksters.
c-kell wrote:
''The Thrilla Of The Villa""
2002 Yamaha Vino Classic S
Engine mods:
Motoforce Evo crank Stage 6 Streetrace kit Dellorto 17.5 man choke
Polini carbon fiber reeds. Gianelli shot exhaust
CVT mods:
Polini Variator. Hebo Driveface. Malossi Winged Clutch Bell. Stage 6 clutch springs
Suspension:
RDR Nitrogen Filled Shock (rear)
Frame:
Home fabricated 6" stretch 2" lower
ZF member #14
Mon Jul 27, 2009 6:12 pm
:( :mad: :mad: o where o where can my bearings be. Ordered my bearings last friday and still hasn't been shipped out.............. . . . . . . . . . . . . . Provo im gettin a little po'd now. . . . . . . . .
Engine mods:
CVT mods:
Suspension:
Frame:
ZF member #14
Fri Jul 31, 2009 10:35 pm
hey hey. I finally got all my parts and i need to know how do the bearings go in the case. Does the open side me the bearing face the crank or does it face away the crank?
Engine mods:
CVT mods:
Suspension:
Frame:
ZF member #14
Tue Aug 04, 2009 9:42 am
Post up some pictures! The side with eposed bearings goes to the inside if you have those bearings.
-H-
3. NGK BR7HS
9. Malossi Up-Gears
Tue Aug 04, 2009 10:15 am
i'll post some pictures later tonight when i get home. So the side that has the exposed ball bearings face the crank right?
Engine mods:
CVT mods:
Suspension:
Frame:
ZF member #14
Tue Aug 04, 2009 12:33 pm
ok sorry it took so long to post some pics but here you go. i already pressed the bearings into the case halfs. and i was wondering if i can still use my belt. im not sure if that thread hanging off the belt will be a big issue. im going to order a new one anyways just to be on the save side of things.
File comment: malossi belt
File comment: malossi beargins 20x47x14
Engine mods:
CVT mods:
Suspension:
Frame:
ZF member #14
Thu Aug 06, 2009 7:29 pm
So I guess that proves it. Malossi brand bearings are SKF.
-H-
Just take some measurements of your belt and post em up. You can compare em to the spec on www.malossi.com
3. NGK BR7HS
9. Malossi Up-Gears
Thu Aug 06, 2009 9:36 pm
update!
My motor is completely reassembled, and ready to be mounted back up to the frame. I got some photos but im using my phone right now to update you guys. My phone won't let me upload photos to the internet. Anyways, i got a question or 2 i want to ask.
Can i use yamalube to pre mix? If not what oil would you recommend?
At what ratio should i pre mix at?
What size main jet would be a good starting point?
List of engine mods:
Athena 70cc big bore kit aluminum
Stage6 hpc 10mm crank
Malossi crank bearing
Gianelli 'shot' exhaust
Dellorto 17.5 carb
Open foam air filter
Engine mods:
CVT mods:
Suspension:
Frame:
ZF member #14
Sat Aug 08, 2009 1:05 pm
Start with a 100 Jet and do your plug chops with a BR7HS for quick plug reads. Pre-mix with Yamalube if you have some to burn up. If your running the dell you might need to do some fine tuning with the multiple jet options available. I'd try and tune it according to the factorypro guide first for CV carbs.
-H-
3. NGK BR7HS
9. Malossi Up-Gears
Sat Aug 08, 2009 5:33 pm
thanks hya for the info on factory pro cv carb tuning, i studied it like a book...
here are those pics i been promising.
File comment: reassembled motor with flat black paint
File comment: stage6 crank
Engine mods:
CVT mods:
Suspension:
Frame:
ZF member #14
Mon Aug 10, 2009 11:09 pm
took my baby out for a break in run today during my lunch and im loving it. I picked up some gas on my way home did a little pre mix of 28:1. She runs ok the low and mid range bogs abit but once it gets into the higher rpm's 8k+ thats when the motor really opens up. But im sure all will change once i get out there and really start tuning the carb.
Engine mods:
CVT mods:
Suspension:
Frame:
ZF member #14
Thu Aug 13, 2009 5:49 pm
update:
carb tuning is on delay. My throttle cable snapped on me the other day. Im gonna go hit up scootershop tomorrow and pick one up.
Engine mods:
CVT mods:
Suspension:
Frame:
ZF member #14
Mon Aug 17, 2009 10:03 pm
heh heh, end result after the stage6 crank, athena bbk install..... enjoy!
http://www.youtube.com/watch?v=oUYCOYi6QVM :D :toot: :rock: :pinetree:
Engine mods:
CVT mods:
Suspension:
Frame:
ZF member #14
Tue Nov 10, 2009 2:01 am
