View unanswered posts | View active topics It is currently Mon Jun 17, 2019 8:23 am
Reply to topic  [ 9 posts ]
 Rear end oil once and for all
scooters and mods: 2008 Zuma with a throttle mod & air screw adjusted!
Post Rear end oil once and for all
Ok, I read through 3 pages of stuff in that rear end oil change thread. I just want to know what the factory recommended oil and weight is. And the capacity for filling the rear end.
2008 Yamaha Zuma 50cc
Wed Mar 24, 2010 11:46 am
scooters and mods: 2008 Yellow BWs 50: PHVA 17.5 mm carb, YES Muffler, TP Trophy 70cc, Malossi variator & clutch, JDM tail
Post Re: Rear end oil once and for all
From the 2008 manual pg 2-2 (2008 SUPPLEMENT)
Final gear oil
Recommended oil SAE85W140 hypoid gear oil
Periodic oil change 0.11L (0.10 Imp qt, 0.12 US qt)
Total amount 0.13L (0.12 Imp qt, 0.14 US qt)
From page 2-1 of the 2005 manual: Yamalube 4 SAE 10W/30 SE or GL gear oil (also on pg 3-11)
You can use EITHER 10W30 oil OR 85W140 gear oil. Pick one and stick with it. With regular oil changes, you add 0.11 litres (0.12 US qt). That should be the amout that drains out when you pull the plug.
I'm using 85W140. Others are using 10W30. Don' get too hung up on it. PICK ONE AND STICK WITH IT.
EDIT:
From the Vino4t manual: SAE10W30 hypoid gear oil
From the Vino 2T manual: Yamalube 4 (10W30) or SAE 10W30 type SE motor oil
From the C3 manual: SAE10W30 hypoid gear oil
From the Vino125 manual: SAE85W140S Ehypoid gear oi
From the 99-02 Zuma manual:SAE 10W30 SE motor oil
Same thing goes... PICK ONE OIL AND STICK WITH IT
YELLOW 2008 BWs 50 - Zumaforums Member #2057
dual headlight mod, C3 Mirrors, TinyTach, JDM Tail light, Low Canadian OEM windshield
Top Performances Trophy 70 cc, MotoForce 17.5 mm PHVA clone 90 main jet (still tuning) with Stage6 Choke lever next to key
Malossi Variator 6 x 5.5g rollers (still tuning) Malossi Delta Clutch Red springs, (still tuning) Malossi Yellow contra spring (still tuning)
YES Muffler(Canadian, eh)
Stage6 43/13 Primary gears. 10.94 final drive ratio
COMING: STR8 oversized fan, Motoforce Evolution crank
70 cc of scootin' pleasure
Wed Mar 24, 2010 1:14 pm
scooters and mods: 2008 zuma - t-mod
I use the gear oil and it works great! Be careful not to overfill or it will be dripping out the tube for a while! I wish they had put a full mark or a dip stick for it , would make filling easier.
08 zuma 50cc
T-mod.
Wed Mar 24, 2010 3:26 pm
Oh man, the yamaha dealer showed me a book this morning thats said recommended fluid "transmission fluid" and capacity was 1.13 us quarts. I laughed at the kid and walked out.
Wed Mar 24, 2010 4:52 pm
As in "automatic transmission fluid? That would ruin the gears in a hurry! ATF has no lubricating ability. Could be worse , he could have recommended brake fluid. :doh:
08 zuma 50cc
T-mod.
Wed Mar 24, 2010 5:35 pm
Im assuming he meant atf. I went to high school with his boss, I am gonna have a talk with him about the parts departments knowledge base.
Wed Mar 24, 2010 11:07 pm
scooters and mods: stock 2001 yamaha zuma - red
i usually have some 10W-30 around so thats what i tend to use in my prebug. no problems at all.
28xx miles
bone stock...for now
Thu Mar 25, 2010 2:04 pm
Sorry to bump an old thread here, but I cannot find any 10w30 hypoid gear oil. I did find this helpful post on another forum.
https://www.bobistheoilguy.com/forums/u ... er=1577154
These guys say that 10w30 hypoid gear oil is a typo or lost in translation, not sure what to do. I just bought a C3 with 2600 miles on it and want to get everything done just in case.
Sun Oct 14, 2018 4:45 pm
10 w 30 synthetic just like what we put in our cars is what my yamaha dealer uses
another dealer uses synthetic gear oil 75or 85 w 140 because that is what is reccomended in the yamaha dealer manual as a first choice
2004 Zuma Malossi sport 70 cc Technigas next r polini green springs stock clutch 2008 zuma torque driver polini high speed variator 5.5 grams sliders Stock Carb 82 main jet 46 pilot jet needle 1 clip rich stock athena 14/42 gears 11 to 1 final ratio 56 mph
Sun Oct 14, 2018 6:42 pm
