View unanswered posts | View active topics It is currently Thu Apr 25, 2019 11:38 pm
Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
 YAMAHA ZUMA 50 - Top Speed (BBK to Gears) w Stock Muffler
scooters and mods: 2009 50cc
Post YAMAHA ZUMA 50 - Top Speed (BBK to Gears) w Stock Muffler
Getting close to finalizing my partslist for this upgade, Though i would get some final opinions and post updates for future modders. Current setup is 09 with throttle mod and only at 4000km. trying to get close to 80km/h and also in hilly area and at sea level.
_______________________________________________________________________________
70CC BLACK TROPHY CAST IRON (Recommended by jmkjr72)
https://www.scoot-tuning.com/Cylinder-Top-Performance-Black-Trophy-cast-iron-70-p/t9931340.htm
NGK BR9HS SPARK PLUG
https://www.scoot-tuning.com/NGK-BR9HS-p/br9hs.htm
PRIMARY GEAR ATHENA 15/50
https://www.scoot-tuning.com/product-p/234-057115.htm
TORQUE SPRING STAGE6 MINARELLI MEDIUM
https://www.scoot-tuning.com/product-p/s6-5216602.htm
MALOSSI ROLLER WEIGHTS
https://www.scoot-tuning.com/product-p/m66900000.htm
REED ATHENA CARBON
https://www.scoot-tuning.com/OEM-Remplacment-carbon-reed-Minarelli-horizontal-p/234-3002.htm
GASKET INTAKE MINARELLI
https://www.scoot-tuning.com/product-p/307-10000.htm
YAMAHA OEM PARTS
14T-14343-41-00 for the 82
14T-14343-42-00 for the 84
Adjustable needle 02-05
wrist pin bearing
How is ring gap adjustment done, havn't found to many threads on the topic?
I am also looking to get two sets of weights for tuning, but i dont understand all the sizes listed?
I have read these carbon fiber reeds can sometimes leave a gap, recomendations? also nervous about screw coming loose, do you guys use red or blue locktite?
Thanks in advance,
Kevin
2009, 70cc Black Trophy TP, 15/50 Gears, Long Belt, Oversize Fan
Fri Mar 10, 2017 9:24 pm
Post Re: Top Speed Upgade Parts List (BBK to Gears) w Stock Muffl
I haven't had issues not using lock titer
Have never worried about ring gap I mean it's got to be at least .006 inches put the rings in the bore square them up and check if you are worried but dot catch them on any of the ports putting them in or getting them out
if you really want to worry about that then squish and port timings
Roller sizes if using the stock varatior will be 15x12 then the grams you want the first numbers are the physical sizes
Sat Mar 11, 2017 7:16 am
OK thank you,
Another thing that is unclear is a/f screw tuning along with pilot jet.
If I keep the stock pilot jet am I still going to be between .5 and 2 turns on AF screw? or will 46 Pilot keep me more in that range? Don't want to be too lean and also at sea level...
Was also wondering if 82 main jet is better since I am stock muffler? Then again I am at seas level...
These are only instructions I could find on Zuma forums
""as for the af screw with it running and warmed up
turn it in gently and then keep turning it out till you hear the revs drop then go back in 1/4 to 1/2 turn
then what you need to do is count how many turns it takes to put it all the way in again and return it to where you had it set
less then 1 turn out you need a smaller pj more then 2 turns out go up with your pj""
P.s...Good video are carb tuning.
https://www.youtube.com/shared?ci=edH24nerEDI
Kevin
Sun Mar 12, 2017 11:14 am
Can't say what is going to be best
Every kit is a little diffrent humidity of where you live plays into jetting if your squish is a little tighter then the next guys you will need diffrent jetting
This is why we tune and we recommend you get multiple jets
That's spot on about tuning the af you have to tune the af to know if you need a diffrent pj
Sun Mar 12, 2017 4:32 pm
K thanks. So then, what do you tune to know what main jet is better. Is that done with plug chop or other?
Wed Mar 15, 2017 10:06 am
scooters and mods: '03 yellow Zuma with Malossi 70 cc, rejetted stock carb and stock exhaust.
I'm running a Malossi cast iron 70cc with the stock exhaust, 46 pilot, 82 main and the needle raised one notch for about 10,000 miles with zero problems, and throttle response is perfect. I'm interested to see how the Athena gears work out for you. Mine accelerates really well but I wouldn't mind a couple more MPH up top.
Malossi 70cc, 82 main, 46 pilot and needle raised on stock carb, stock exhaust, air cleaner and clutch.
Wed Mar 15, 2017 10:15 am
scooters and mods: 2005 Bws Dual headlite mod1989 zuma with 70cc kit,up jetted carb,dopler air box custom exhaust made outta stock one.
Im getting about 70 kph.41mph. with my setup, i just ordered an Ncy secondary slider sheave the other day :q:
We will see how much difference a worn out curve td compares to a aftermarket straight groove one...
2005 BWS (Blue Bandito)
- 70cc Athena bbk (Sport)
- stock carb,85Mj snorkel removed
- stock clutch
- ncy adjustable td.
- malossi white torque spring
- malossi yellow clutch springs
- michelin bopper tires
- dual headlight mod
- tun'R rear shock
1989 Zuma (Red Dragon)
- 70cc Hebo bbk
- Doppler air box stock carb
Wed Mar 15, 2017 3:35 pm
Never heard of Secondary slider sheave, sounds interesting..
Screamingyellow, It would be nice to try setup without gearing first, but seems like unneeded tuning. Hoping to order parts soon, will post results when time comes.
___________________________________________________________________________________________________________________
My question now is what weight range should i buy? 2, 3, 4 sets? What weight combinations should i buy?
Will these work in stock variator? They say long life and are cheaper?
JASIL HIGH QUALITY ROLLER SET
https://www.scoot-tuning.com/product-p/437-6068000.htm
Sun Apr 02, 2017 3:32 pm
Using the stock exhaust, I doubt you'll need different weights. The clutch and belt on mine are stock and OEM. 0-40 acceleration is excellent (it jumps off the line really well), but right about 44 or 5 it starts to round off. I look forward to your results :)
Mon Apr 03, 2017 2:29 pm
Since I am changing torque spring Im going to need some heavier weights. Guess I will order a few. Am in very hilly area so harder torque spring is desirable.
Does anyone know what piston ring gap should be on new 70cc ?
Sun Apr 23, 2017 11:42 am
I believe minimum is is .005" or .15mm, same as stock set up. On the Malossi kit the gap was .007" out of the box and it's been great for a long time.
Tue Apr 25, 2017 7:03 am
Scoot-tuning.com got back to me.
"Ring cap must be 0.008mm
Stephan Pouliot"
Tue Apr 25, 2017 9:25 pm
Has to be .0008 inches but good to know.
Wed Apr 26, 2017 7:03 am
scooters and mods: 2009 BWS 50, 70cc BBK, Dellorto Racing carb, Technigas exhaust
Have you installed the parts yet? I am curious what kind of results you have gotten if so.
Sun May 20, 2018 5:13 pm
Post Re: Yamaha Zuma - Top Speed (BBK to Gears) w Stock Muffler
Hello Everyone... Here is a quick update... Better late than never...
Final speed on this build is hovering around 70km h. Not the speed i hoped for but the gearing is saving my engine im sure.. Take off is great though...
Next time i would order gasket for the gear cover and dont forget proper silicone for bottom gasket on jug. Also pressure test is a must IMO. The ring gap on Top Trophy was already perfect
THe medium spring i got was was to strong for even the heaviest rollers i got, i think 8-9gram. It will be replace on next round of parts..
The Reeds are a waste of time without the housing, So make sure to buy them one piece...
I am at sea level with jet pin on richest setting and #84 is too lean, having some overheating going up steep hills here. My dealer Doesnt have a #86, but the have #88 So i might try that.
I have orderred the next round of parts and hope to make a new thread once i reach 80km/hr goal
http://www.scootertuning.ca
-Variator Polini HI-SPEED Minarelli
(https://www.scootertuning.ca/en/variators-sport/7008-variator-polini-hi-speed.html)
-Drive belt Athena Speed Minarelli Long
(https://www.scootertuning.ca/en/variators-sport-drive-belt/7083-drive-belt-athena-speed.html)
-Variator roller weights adjustment set Polini - Choose : 16x13mm 6.50g 7.00g 8.00g 9.00g
-Oversize air fan Motoforce RACING
THanks for your patience...
Thu May 24, 2018 9:44 am
