View unanswered posts | View active topics It is currently Wed Jun 26, 2019 12:01 pm
This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
 Gear box Sealed Bearings, keep or remove
Post Gear box Sealed Bearings, keep or remove
Good afternoon all,
I just bought some new bearing to replace the one in the gearbox. However, they are sealed. Should I keep them like that or remove the seals before putting them in?
2004 BWS/Zuma
Malossi 70cc Cast Iron
Big Air Box
Upjeted Carb
Malossi Wildlion Exhaust
Malossi Fly Clutch 105mm
Malossi Primary Gear 13/44
Polini Hi-Speed Variator Kit with 5.5g weight
Tue Jul 17, 2018 1:37 pm
Post Re: Gear box Sealed Bearings, keep or remove
I’d only replace it if they got dirty or if you powder coat your cases
Tue Jul 17, 2018 2:01 pm
