View unanswered posts | View active topics It is currently Thu Jun 27, 2019 3:59 am
 Oil injection on 70 cc Athena BBK
Post Oil injection on 70 cc Athena BBK
Hi this is my first post I have a 2003 Yamaha Zuma 50 and I am installing and Athena aluminum 70 cc Big bore
kit. I am going to re-jet my carburetor from Size 80 main jet to 90 in the star carb. My main concern is do I need to change the oil injection jet or drill it bigger?
Any help would be greatly appreciated
Wed Sep 05, 2018 9:26 pm
Post Re: Oil injection on 70 cc Athena BBK
No you can run the stock oil pump as is
Getting a big enough carb to flow air and fuel mixture is more important most switch to a 17.5 or a 19mm carb
a alternative is put a trail tech temp gauge and watch it close .
Think of baking a cake 325 is good 375 is getting too hot baking a pizza 400 degrees is terrible
2004 Zuma Malossi sport 70 cc Technigas next r 2008 zuma torque driver polini high speed variator 5.5 grams sliders malossi delta clutch yellow contra yellow clutch springs Stock Carb 82 main jet 46 pilot jet needle 1 clip rich stock athena 14/42 gears 11 to 1 final ratio 56 mph
Sun Nov 25, 2018 6:26 pm
Users browsing this forum: Google [Bot] and 3 guests
