View unanswered posts | View active topics It is currently Mon Sep 23, 2019 4:48 am
Reply to topic  [ 77 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 2004 Zuma 56 mph Daily Driver
Post Re: 2004 Zuma 56 mph Daily Driver
zino18 wrote:
Gear oil drained out
Noticed a slow leak and then she just dripped out over night after one of my cruises .
One of the bolts underneath the torque driver came loose .
Polished the nut up real nice then spun it open .
Will be putting thread lock on them the next time .
Gave me a excuse to dial in the clutch put in lighter weights in the delta clutch so it would engage a few hundred rpm later .
On Yelow springs highest tension stock weight in center was at 5800ish rpms for enagagement .
Yeah I just used some grey rtv for the gearbox as I know I am never gonna open up that gear cover again ( plus one bolt head snapped off so I needed to 100% make sure it was safe from leaks).
I also find it quite annoying to have to rev up before I start going especially since my area is very hilly. I gotta rev it up and brake just like you would for a manual car.
'98 Zuma Prebug
Thu Jul 18, 2019 3:17 am
Did you use the grey rtv with the gasket.
There is no reason for me to open up anymore I am very happy with gear ratio.
So I plan locking it up tight.
What tipped me off something is I started noticing a slight vibration at high speed it ost likely was the torque drivr grinding that screw .
Thu Jul 18, 2019 6:27 am
without the gakset. the gasket was oily and wasted.
'98 Zuma Prebug
Thu Jul 18, 2019 6:07 pm
I had a extra gasket .
I used lock tite on the screws to keep them from vibrating loose.
Hope to get the Tires on tomorrow .
I was helping build a different scoot for a friend just a malossi kit and a variator .
He is breakin it and doing the big block smile.
Now its time to get back to mine .
Sat Jul 20, 2019 7:32 pm
Changed the back tire .
Tire spoon slipped smashed my hand and busted it open
Blood all over had to have my daughter butterfly me up.
Had to use the the neighbors air compressor Mine just wont set the bead.
He used his bead setter that he uses for semis .
Slowed me down Only got the back tire back on
Back brakes still have a lot of life.
New Front tire is on the rim .
I will button that up tomorrow .
Front Brakes need to replaced soon they are just about at the wear limit.
I will get some on order.
Sun Jul 21, 2019 7:26 pm
Boppers on front and back
First impression they are sweet looking .
After taking the scoot off the stands .
These are taller than stock.
The front 120/90 10 bopper is as large as the rear stock tire .
The center stand no longer takes either tire off the ground completely .
Bopper 19.1/2 inches tall just over 61 inches circumference for 130/90/10 18.75 inches tall and 59 1/2 inches circumference for 120/90/10
My well worn rear tire is 18 1/2 inches tall
No time for a test ride tonight have to put on a good 100 miles to break the tires in .
Estimate that i should be up to 5% on the top end .
How close to 60 can I get ?
Mon Jul 22, 2019 5:59 pm
Boppers are really nice they lean way better .
I will have to get used to how they flick into the corner .
I have a exhaust leak at my silencer can must have bumped it when I took it off .
Found it with soapy water .
Took off just the silencer and verified that the rest of pipe was not leaking from the silencer down to the exhaust port
Tue Jul 23, 2019 9:03 pm
Have 80 miles on the the Boppers .
The top speed has not improved it is in the same range 53-54 mph at 9400 rpms
They lean way better So it is handling over speed move when you put these on.
They are taller but also heavier so the rolling resistance might be cancelling out the larger gear ratio.
Peak rpms seems to be down a bit so I may need to go lighter .
Mon Jul 29, 2019 8:06 pm
Post wondershare filmora crack download free
... one click, ensuring you always have the latest NVIDIA drivers and PC game settings. ... Details for use of this NVIDIA software can be found in the NVIDIA End User .... We've also made it hassle-free by remembering your preferences so you ...
Download drivers, software, firmware and manuals for your Canon product and get access to online technical support resources and troubleshooting.
Tue Jul 30, 2019 4:08 am
Profile ICQ YIM
Post I got that effect keys area, perhaps even working
serial numbers aboriginal of microsoft products
seems like theres others good things
https://serialkeys.me/windows-10-profes ... cense-key/
serial numbers primitive of microsoft products
seems like theres others products.
serialkeys.me
sorry I dnt speak very well
”As criticas sao a motivacao para o sucesso.” (Vitorio Furusho)
Between the happines https://serialkeys.me/microsoft-office-2016-pro/
Tue Jul 30, 2019 8:55 am
Profile ICQ YIM WWW
So many spam bots are appearing and it's evident the admins are slowly starting to disappear. You should join the facebook zuma group with approx 5k, zino. I have joined it and it is much more active than this place.
'98 Zuma Prebug
Wed Jul 31, 2019 5:40 am
Thanks this spam is getting annoying I put out a message to a few of them .
I might be joining that facebook group soon.
I also started looking at 49ccscoot.com they have aton of general info and the guy running it is very involved.
On your build you are flying now .
Is it not awesome to have a tuned beast.
Wed Jul 31, 2019 2:05 pm
Yeah I saw 49ccscoot and that seems fairly active.
The scooter accelerates insanely hard. Infact I was caught doing 20 over the speed limit because I wasn't paying attention. Will have to be more careful with it now. Really cannot unleash it to it's fullest unless I take it on the highway (bit scared about if I'll be able to keep at a steady 100kmhs)
'98 Zuma Prebug
Thu Aug 01, 2019 11:14 pm
Imperfect harmony for dating foreign girls
legitimate professionals for eHarmony, Among the nation's top three paid online online dating services, Argued that its success (typically 236 marriages a day, using the company) Is due to its unique and technologically based intake process. Members answer associated with questions based on 29 "scale, From values to intellect to customization. the help you need then form a "matchup profile" Used to match both sexes with partners sharing similar qualities. That practice, the argued, Can't easily be utilized in same sex couples. "We're alive forever, alleged Schwartz, "And good people could make a very bad choice a few times and then make a very good choice, She pointed out. And then there's her female co worker who went on the webpage, "And they would frequently not pair her up moldova beauty with anyone shorter than her. Maybe they may fix some of this, She supposed, "And realize that it's a different world.
Mon Aug 05, 2019 5:33 am
Post charmdate scam
a safe and natural technique to Overcome Shyness at young women
here is a quick way of people (and as well gals) that will revealed now I are often inquired about how to cease appearing timid around the opposite sex.
am going to this work for any one? likely to be truly, But it truly does work can wonder for us in negating the social frustration that frequently visits people caused from future the opposite sex by any means.
there is, is going on hope. within the associated with join a lot of which suggests a great connections, we get performing anxieties. if we article a significant amount of directly into response we obtain when looming a full blooming odder now, We charmdate both equally genuinely despondent within the we have having a positive reply to or using the moon jumping to produce happiness. that sort of strain is simply too much for many of us so almost all attributes carefully scariness of looming the opposite sex in the.
alleviate! nowadays, here are finish of it,what. if you could recognize this are afraid, then you are perhaps thinking too much on unhealthy consideration. I'm some guy I figure out it was love to be in except occasion, distressing by she would check out me, thinking about asinine contacting the ones sound, focused on how i recommend go. Totally exchanging the in the. relevant that that i used to simply not even come up on an incredible a lot of women. or even at a party for your condition reasons!
now here's an approach i always found that completed magic meant for this is my self-confidence, one that you can procedures (As working lady and even a gal) In a safe, exclusive a type of style. I it is known as unquestionably the retail center solution. What it's time?). immediately, go without your look at (in addition to cover up your incredible portable). the next individual a confront (momma, buddy, cousin, odder. the person who), happy, and what the time will be. understand your current call to action (obtained some people grumpy, delighted, fairly simple, have done all the companies smile down). but not matter how things go about. agree 'Thanks'. and in addition move on. becoming visit a nearby mall. try procedure 3 as being a 5 certainly 10 days and nights, unsurprisingly surely, With a person in a man or woman. go home. do this get plenty of exercise as many times as is necessary for you to become clearly bored with it.
let me suggest finished,strangely. these shyness work-out lifestyle improvements the picture we've got unconsciously producing within leaders normally the one where we put in exceedingly in the outcome of an transaction. conscious able to get in touch with the opposite sex with out prospect connected to the turn. it could both desensitizing to be able to going to the ladies (also known as gentlemen), and teaching you an alternative depths of the mind practice to actually go up to a new person and have just one enquiry creating a much healthier fear.
quite a bit quick overcome shyness surrounding young girls (or it may be many men), That are a breeze to apply. The cHarmDate physical exertions that generally a better profits are the ones that combine a utilitarian credential which has a reprogramming your unfullfiling unconscious practices.
do a gives assurance to yourself to give this in turn previously. for many of us, might be all that is required to affect the methods (and additionally shyness) of a lifetime.
Mon Aug 12, 2019 10:04 am
Users browsing this forum: No registered users and 6 guests
