View unanswered posts | View active topics It is currently Thu Jun 27, 2019 4:01 am
 01 Zuma 50 Setup
Post 01 Zuma 50 Setup
I have an 01 Zuma 50. It's bone stock and does around 40 mph. I want to mod my scooter to get more speed. The first thing I plan to do is derestrict it. Does anybody have a good how to video on that? After derestriction I don't know what to do. Looking for advice. I'm willing to spend a couple hundred bucks, but not much more than that. I'm willing to lose a bit of acceleration in order to gain speed. This will be a daily driver so it needs to be reliable. I don't care about legality (I'm willing to use a big bore kit, racing parts, etc.).
Mon Oct 01, 2018 7:12 am
Post Re: 01 Zuma 50 Setup
If you still need help I have 2 vinos
At 40 mph you sound like you have the basic de restrictions done already.
Which are exhaust pipe opened up large enough to stick a thump in when its done .
The wedding ring band removed from between the 2 variator halves It keeps the varaiator from closing all the way on the belt.
I would go bbk first and buy a couple jets larger than stock 64 from yamaha .
If they have none buy mikuni 11/22 style start get at least 70 75 80 85 from them Mikuni numbers and Tk numbers re not the same so you should start out really high and gradually work down.
Fri Dec 14, 2018 6:04 pm
Users browsing this forum: Google [Bot] and 3 guests
