View unanswered posts | View active topics It is currently Sun Jun 16, 2019 10:37 pm
Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
 2T variator 'collar' outside diameter?
scooters and mods: 2008 Zuma, 2012 Ruckus
Post Re: 2T variator 'collar' outside diameter?
OK - finally the answer to the original question...
I measured the OEM collar - or at least the one that came in my 2008 Zuma that I've owned for a bit more than a month...
And, it's about 18mm.
I also measured the hole in the OEM and NCY variators and they're also about 18mm.
I just recently bought that super tranny kit...
Maybe your 20mm collar is a 2001-2007 thing. I read that Zuma things changed in 2008 with throttle cam restriction, gearing change, etc. Maybe they also changed the variator specs?
here are some photos:
Matte Black 2008 Zuma 50: NCY 70cc Sport kit, NCY exhaust, Dellorto 17.5, NCY Clutch with yellow contra spring, Malossi MultiVar with 8g Dr Pulley sliders, Malossi Kevlar belt, Sport 70 airbox, Doppler intake manifold, Stage6 Reed cage, Nology hotwire, Malossi RS3 shock, TTO temp and tach, Boppers.
Fri Oct 12, 2018 7:35 pm
Awesome, thanks Jack! I think the issue is that the variator and collar that was in there was not actually stock. Someone must have replaced it with and AM one that had the 20mm dimension. So to use the NCY, I would have to locate a stock collar.
Thanks for all of your immense help Jack!
Sat Oct 13, 2018 5:37 pm
$4.38
[url]https://www.zumasrusstore.com/collections/zuma-50-02-11-parts/products/variator-yamaha-stock
[/url]
Sat Oct 13, 2018 5:53 pm
:cheers: :cheers: :cheers:
Sun Oct 14, 2018 5:32 am
Users browsing this forum: zino18 and 6 guests
