View unanswered posts | View active topics It is currently Sat Sep 21, 2019 11:18 pm
Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
 Yamaha 1998 acceleration and top speed issue
Post Re: Yamaha 1998 acceleration and top speed issue
post your sig line up as you mod so others can chime in and help
Wed Apr 17, 2019 8:02 pm
zino18 wrote:
You posted while I was typing .
Jets are so cheap you might as well have the perfect ones for your set up and where you ride elevtion and temature range wise
I was scrolling through the forums and saw that jmkjr72 said "the prebug runs a 12 mm carb and it is too small to run with a bbk you need a larger carb". I am not sure if I should bother trying to upjet and just get a 19mm carb.
Anyways here is some info I have gathered. I found out that the main jet was a #90 and the pilot jet was a #50. What sizes do you recommend for me? (I am +20m above sea level and am in a pretty hot area like 30 degrees C).
I also saw that the spark plug installed was a BPR6HS whereas stock is supposed to be BR8HS. Here is a pic of the spark plug. https://imgur.com/a/LYT69ce I think this may have been affecting my zuma quite a bit.
'98 Zuma Prebug
Wed Apr 17, 2019 10:09 pm
I went ahead and bought a 17.5mm dellorto one which comes ready for manual choke for decently cheap.
https://www.scootertuning.ca/en/carbure ... &results=1
It comes with a 90 MJ so I think that will be fine right?
'98 Zuma Prebug
Wed Apr 17, 2019 11:51 pm
PLugs are a performance part for a 2 stroke so the right one is critical .
That one by the look of it is holding you back.
The 6 is hotter than the 7
The 9 is correct plug for aluminum kit like the athena it is a cooler plug .
I still like to have extra jets just to dial it in closer
It also helps to know what way too rich sounds and feels like and as you drop jets wht going lean sounds like.
As long as you can get them locally or through ebay .
plug chop will tell you if you are close enough.
That is a very good vendor to buy from
Jmkr is a very good tuner so folowing his advice will serve you well.
Thu Apr 18, 2019 6:12 am
Btw to everyone who is reading this I foudn the issue. The oil feed line was cracked and so the piston was never getting lubricated hence it seized so many times. I've fixed it now and you can continue reading about my project here. viewtopic.php?f=48&t=28663
'98 Zuma Prebug
Tue Apr 23, 2019 9:58 pm
Users browsing this forum: CalvinGow and 1 guest
