View unanswered posts | View active topics It is currently Mon Sep 16, 2019 7:56 pm
Reply to topic  [ 8 posts ]
 Zuma 70cc Carb and Throttle Cable Upgrade
Post Zuma 70cc Carb and Throttle Cable Upgrade
I bought the following kit from scootertronics to add to my already installed 70cc kit:
http://www.scootertronics.com/zuma-carb-upgrade.html
This is the cable by itself:
http://www.scootertronics.com/two-strok ... cable.html
It came with a "mikuni style" single throttle cable that I installed, adjusted to maximum, and still have some crazy slack in the wire. The sheath itself seems too short.
First, where should I attach the cable so it doesn't flex or pull on the carb itself (held on only by the rubber intake) and second, is this simply the wrong wire for the job or should I also get a different inner throttle sleeve for the handlebar?
Such as: https://www.denniskirk.com/motion-pro/c ... 903153.sku
---> 2009 YW50 Zuma <---
Dellorto 17.5 Knockoff
Stage6 70cc Iron Cylinder Kit
Leo Vince ZX Exhaust
Fri Apr 12, 2019 4:32 pm
Post Re: Zuma 70cc Carb and Throttle Cable Upgrade
Wait, that's not a Dellorto carb, is it? I've been looking for a 17.5 auto choke, and everywhere I've found them they're nearly $200. What's going on here?
Stock '05 Zuma - in the wild somewhere.
2015 Zuma - Stock. For now.
Sat Apr 13, 2019 9:36 pm
On the throttle tube
Ok you can try to mod and try to make it work and then one day when you think you are shutting your throttling down your throttle will roll over and drive right through the back of your garage.
Or do it right and buy the throttle tube for a single pull carb that you linked too
Here is a good thread
viewtopic.php?t=12321
The one thing I would add when your putting the grip on the plastic throttle tube get it on as far as possible and you can throw it in the microwave for 30 seconds to help loosen it up so you can slide it on the rest of the way .
Sun Apr 14, 2019 7:18 am
Pat
That old saying you get what you pay for applies but sometimes you get lucky.
jmkrjr72 has a very strong opinion for not ordering from them There stuff is to hit or miss.
I am in the market for a dellorto carb also might have to wait for the black friday or boxing day sale on scootertuning.ca 20% off helps .
Other wise I will just leave my wish list around for my wife to find she would do that with her Victoria Secret catalog.
Sun Apr 14, 2019 10:28 am
zino18 wrote:
Pat
I read around about them, too, and decided to take the risk. It took two weeks to get the stuff, but the carb, what seems like a dellorto knock-off seems of reasonable quality and has autochoke and an oil line barb. It came with that throttle cable, which is too long for the job, though, and an air filter.
I've resorted to buying the correct single-cable throttle tube and cutting the cable a bit to have the proper tension. I had it at maximum adjustability and it still had far too much slack in it. Will update soon with my thoughts on the scootertronics carb. Got it with a 97 main jet.
It's a knock-off but has auto-choke and an oil fitting.
Tue Apr 16, 2019 4:58 pm
If the carb gives you trouble
With that cast iron kit you could always rejet the stock carb to a 82 or 84 main with a vino pilot jet.
If the carb works well you could sell your stock one to one our members .
and get half your money back
Tue Apr 16, 2019 7:16 pm
Thought I'd post an update.
Everything is installed, the strange throttle cable is modified and installed, but the handle can still roll back. Working on a fix but there isn't much space inside the metal shrouds to work with.
Definitely a lot faster with the 70cc kit and dellorto knock-off. Had to spend a day tuning the air-fuel ratio but that's hopefully sorted.
In warm weather, should I be seeing smoke out the exhaust or not? It's relatively smokeless, which scares me a bit, for a two stroke.
Rollers that came with the Leo Vince exhaust are perfect for the kit.
Sun Jun 02, 2019 4:25 pm
The better oils barely smoke .
Yamalube smokes
Mon Jun 03, 2019 6:43 pm
Users browsing this forum: No registered users and 10 guests
