View unanswered posts | View active topics It is currently Tue Jul 16, 2019 11:42 am
This topic is locked, you cannot edit posts or make further replies.  [ 193 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12, 13  Next
 $$$$$$$$ FREE SHOP MANUAL’S $$$$$$$$$$
Post Re: Service manuals
Do you really think that's something that you'd find in the service manual ??
If I did find the number.or.numbers ... what would you do with that information ??
That's kinda an odd question ??
zooomie wrote:
for someone with a service manual.
what is the air/fuel ratio for the c3/50f?
I'm just saying ... if someone told me what that number was ... I wouldn't know what to do with it.
I don't think that it's a static# ... I think that it changes over the whole power band from idle to WOT.
I guess that I'm looking forward to seeing someone WITH KNOWLEDGE ... answer this !! !!
Wed Jun 20, 2012 3:01 pm
I guess there is nothing you can really do with the numbers, just curious as to how they have the ecu set.
I don't see why it wouldn't be in the manual since it ks technical info.
I like to know as mjch as I can about my engines.
Wed Jun 20, 2012 3:18 pm
found it
http://en.wikipedia.org/wiki/Yamaha_XF50X
Wed Jun 20, 2012 3:22 pm
oops, mksread that.
compression ratio is 12-1
Wed Jun 20, 2012 3:30 pm
I didn't see an air/fuel ratio #
I did see a compression ratio 12:1
Still ... now that you know what it is ... what do you plan to do with that bit of information ? Are you planning on shaving the cylinder for more compression ? I hope that you consider EVERYTHING as an alternative.
What are you planning ?
zooomie wrote:
oops, mksread that.
Wed Jun 20, 2012 3:44 pm
I wasn't looking for the comp ratio, but while were on the subject, can the comp ratio be adjusted as easy on a 4t as it can be on a 2t?
Wed Jun 20, 2012 9:22 pm
There's lots of parts $$ $$ $$
different heads, pistons/cylinders, cranks.
Wed Jun 20, 2012 9:26 pm
I was thinking more along the lines of squish clearence. I assume it would be more difficult on a lc vs ac. On my 2t zuma, it was all about the gasket.
Wed Jun 20, 2012 9:30 pm
The compression ratio can be adjusted by one of several means.
#1 a higher dome piston
#2 a smaller combustion chamber
#3 a shorter deck height{the distance between the piston top and the combustion chamber top} {usually done by shaving the head in a milling machine}
#4 use a longer rod
As far as I know nobody makes a high compression piston or a longer rod but there are shops that will custom fabricate them. Redesigning the combustion chamber would require a large amount of engineering and a very good machine shop. The third method is the only one that is fairly easy and cheap{be careful that the valves do not hit the piston!}. Sometimes just using a thinner gasket can give a little more{but not much}.
The stoichiometric air to fuel ratio for a gasoline engine is 14.7:1 but very few engines run that lean. Most are 12.5:1 - 13.5:1, being a fuel injected scoot it is probably closer to lean than rich. Manufacturers rarely list this number by the way. The best way to find out is to use a fuel/air meter.
08 zuma 50cc
T-mod.
Wed Jun 20, 2012 9:47 pm
if compression is too high, it results in pre-ignition. When maching a head or rasing compression by the aboce methods, how can you be sure that it isn't going to fail? I guess it really isn't worth playing with unless you are dragracing...
Wed Jun 20, 2012 10:21 pm
Not worth playing with ??
Well ... that would mean that there is no desire for a few of the aftermarket parts available.
But then ...
BBK & stroker cranks are meant for LARGER DISPLACEMENT.
Thu Jun 21, 2012 5:21 am
scooters and mods: 2004 Yamaha Zuma 50
For some reason I can't get it to download. Could some one email me the pdf for a 04 Zuma 50 to catchingchrome@gmail.com
Thanks
Pete
2004 Yamaha Zuma 50
Headlight Mod
Taillight Mod
SL26 Pirelli Tires
WOLO BAD BOY 419
Mon Jun 25, 2012 9:43 am
scooters and mods: 2009 Zuma 125-C3 Mirrors, GPS Ram-Mount, Stebel M80 Magnum low tone horn, KS/BTX Forward Pegs, Rear Rack w/ GIVI trunk
Find DerHan's signature line. He has a number of links to Manuals right there.
2009 Zuma 125 picked up 9/21/2010 with 9/10 of a mile on the odo
KS/BTX Forward Pegs, Rear Rack with GIVI trunk
Clocks4Bikes Handlebar Clock, Termoscud Lap Apron (seasonal)
VA Tag: 96 MPG
Rolling Thunder/Ride of the Patriots 2012
Rolling Thunder/Ride of the Patriots 2011
Member # 1807
http://www.facebook.com/steven.levine1?ref=name
Gone, but not forgotten:
2008 Zuma 50--FAREWELL PARTY-SEPTEMBER 30, 2010
Co-SOTM November 2009
Rolling Thunder/Ride of the Patriots 2010
Tue Jun 26, 2012 3:18 pm
You are exactly correct ... took me less than a minute to download that ... Thanks !!
2004 Yamaha Zuma 50
2002-2011 Yamaha Zuma 50
Tue Jun 26, 2012 3:49 pm
Guys if you want service manuals go to this site right here;
http://thescooterprofessor.proboards.com/index.cgi
You name it they got it including zuma, vino, C3 and other Yamaha manauals. Got to register to view them.
Tue Jul 24, 2012 4:33 pm
