the new Stage6 Sport Pro Mark II cylinder kit
| Author |
Message |
OveRReV
Joined: Sat Oct 10, 2009 8:42 am Posts: 1019 Location: Gapan city, Philippines
_________________ Overrev Tuning
Yamaha Aerox R MHR Team 6T 70cc (max tuned) + MHR Team Crank + SKF 6204 TN9 C3 bearings + Malossi VL12 reedvalves + Yasuni C21 exhaust pipe + Keihin PWK28 carb + PVL digital inner rotor ignition + Polini Evo SS9 vario kit + Bando belt + Polini 128mm rear pulley + Malossi red vario spring + Malossi Torsion Controller + MHR black clutchsprings + Delta clutch + Wing bell+ Polini 15/42 gear kit + Malossi RS24 rear damper + Bridgestone Racing Battlax tires + Aprilia rally 12" wheels
my "humble" trackday toy, 90+mph.
| Thu Jul 07, 2011 10:40 pm |
jmkjr72
Joined: Thu Mar 20, 2008 5:27 pm Posts: 13378 Location: greenbay wi
 Re: the new Stage6 Sport Pro Mark II cylinder kit
is this a kit that uses the standered crank or do you need a stroer crank
_________________ 2008 zuma dual headlight mod koso mirrors liquid cooled polini corsa kit leo vince zx stage 6 variator rally kit custom red paintFUEL INJECTEDsoon to be 100cc 2008 stella olive custom ported 177 cc kit dechromed ford tear drop tail light alive and breathing and awaiting cosmtic surgery thanks to an donkey hind quater hole cager 1985 elite 150 how long can i leave it stock
| Fri Jul 08, 2011 4:04 am |
backinblack
Joined: Mon Sep 01, 2008 6:53 pm Posts: 3788 Location: RICHMOND,CA
Wow.  What an improvement over the MKI. Is it available in the states yet?
_________________ 2001 ZUMAII - Tires TBD Motor #1(2008): Athena Sport BBK, Ported case, Power 1 HPC crank, Yasuni City16 (fully derestricted), Stage 6/Mototassinari V-Force 3 reed cage, OKO 24mm flatslide carb, S6 R/T rear facing manifold, running pre-mix, S6 BIG filter,Malossi drive face, lightened flywheel, Lightened Athena vario - (22.5g), S6 R/T WingCooler Bell, NCY TD, Malossi Delta clutch 107mm- 8K engagement, Malossi red Contra w/Malossi Torsion Controller.
| Fri Jul 08, 2011 6:51 am |
Nick Batzdorf
Joined: Tue Jul 08, 2008 9:16 pm Posts: 7575 Location: Los Angeles area
A few stupid questions (sorry):
- Which line is what?
- Does that relate to reality, or is it just on the bench - i.e. does it really make all its power between 9-14K?
- I assume "Sport Pro" means "for scooters being ridden on the track for sport," right?
'05 Z50 6650 miles, Athena 70cc with Polini head (.9 squish now, 155 lbs. compression using .2mm base gasket - yes, #155!); Leo Vince ZX with silencer from ZX-R; Athena variator around 30G but still tuning; 107mm Malossi Delta clutch (highly recommded upgrade); '08 fixed & sliding sheaves; Malossi yellow contra spring; 50/15 Doppler helical upgears (12.22:1 ratio); reeds cut out of Polini 30mm sheets; dual headlight wiring; C3 mirrors; 17.5mm Athena Dellorto PHVA carb, A12 needle/36 pilot/88 main/45 starter, snorkel removed from stock airbox; autolube pump (no freaking premix!); Trailtech TTO tachometer and temp gauge.
| Fri Jul 08, 2011 11:38 am |
kriden
That's quite an improvement! But, it doesn't even get close to peak torque until 9.5K RPM? Wow. Do you know what the rest of the test machine setup was for these dyno runs? Any idea if they're doing a MKII for the air cooled cylinder as well? I was planning on picking up an AC S6 Sport Pro kit for this winters project.
| Fri Jul 08, 2011 1:43 pm |
Nick Batzdorf
Ah, I zoomed in and see which is which.
| Fri Jul 08, 2011 4:13 pm |
cathy_liebchen
Joined: Thu Jul 24, 2008 8:49 am Posts: 643 Location: GEORGIA
beautiful kit
_________________ 2009 Yamaha Zuma 155 K2 pipe, 11 gr., RRGS shocks and variator 2009 Vespa GTS250i; Akra; Bitubo; Clauss 2009 Yamaha Zuma 125 11 gr., 1500 springs 2005 Yamaha Vino 70 AIRSAL, stock airbox and exhaust 2010 Honda Elite 110 stock office runner 2010 Honda SH150i, 12g sliders 2006 Vespa LX 150, 2006, Sito plus, 9.5 Dr Pulleys, 38 idle jet 1979 Vespa P200, Sito plus, 118 jet, drilled air filter, the best!!
| Fri Jul 08, 2011 4:32 pm |
jni
backinblack wrote: Wow.  What an improvement over the MKI. Is it available in the states yet? No. According to the S6 forum, the first production batch will be out in August. Here's the relevant thread: http://www.scootertuning.de/stage6-deve ... rkits.html
_________________ 2008 BWs/Zuma. Athena 70cc sport cylinder, Athena racing crankshaft, Athena primary gears (11:1 total ratio), Athena variator with Polini front pulley (6x4.1g weights) , Athena belt, Stage6 Pro exhaust (Athena), Dell'Orto 19mm with Polini choke lever, Koyo high-speed main bearings, Polini 2G clutch, Boyesen reeds, stock airbox.
| Sat Jul 09, 2011 8:07 am |
OveRReV
jmkjr72 wrote: is this a kit that uses the standered crank or do you need a stroer crank it's for standard stroke 39.2mm cranks, depending on the pipe you may or may not have to change the stock crankshaft.
| Sat Jul 09, 2011 8:58 am |
corrosion
Joined: Sun Feb 28, 2010 12:41 pm Posts: 1087 Location: Meadowbrook, PA. 3rd / RFTS
Looking at the Photos, Looks like it is more like S-6 race than sport. bridged exhaust port, The intake ports are huge, in comparison to a MK-I. They don't show you a piston. Then Again this a LC.
_________________ Stage 6 Street Race- 12mm Piston .08 Sqsh, Stage 6 HPC 12mm Crank, MVT Inner Rotor, Leo Vince GP. TNT- adj- injector oil pump Y-plate, Malossi Over-Range Var-46.5 Slider's,Torque Boost Rear Pulley & Stage 6 k-belt, S-6 Soft Contra, Stg 6 MK-II Clutch + bell, Wht/Sprg,@4800rpm & 6 Wolfram, 15-50 up gears, Moto Tassinari VF3 Reedcage,Dellorto 21 Blk /MJ #-92,48 PJ W-9 2nd , 50*Slide, OEM Airbox , Snorkle out, 5 vents, Side Stand, Daytona Style Alloy Wheels, WD torsion arm, Stage 6 R/T Multimeter, Strt8 HD Fan, Pirelli Front- SL 26 - 120/90/10, Pirelli Rear- SL 26 - 130/70/12
| Sat Jul 09, 2011 1:01 pm |
jmkjr72
yeah its lc so the port timings are going to be a bit more aggressive but overall it will be similar for those of you that are ac
| Sat Jul 09, 2011 1:57 pm |
backinblack
Gracias! Still gotta find a scoot to slam my S6 MKI Race AC on. Maybe an LC mini stroke with the MKII?
| Sat Jul 09, 2011 7:09 pm |
buguy
Joined: Tue Mar 22, 2011 3:04 pm Posts: 4472 Location: Port Orange, Florida
Am I mistaken or does that say on the upper right "S6 Sport AC"? Maybe the dyno is for an air cooled version?
| Sat Jul 09, 2011 8:29 pm |
NME
Joined: Thu Jul 29, 2010 10:39 am Posts: 1099 Location: Savannah, Ga
buguy wrote: Am I mistaken or does that say on the upper right "S6 Sport AC"? Maybe the dyno is for an air cooled version? Wondering the same...
| Sun Jul 10, 2011 3:38 am |
jni
Yes, the dyno graphs posted on the S6 forum are for the AC versions; one is for the sport cylinder, the other one for the race cylinder, both tested with a with a (race) R1200 exhaust. Here is the link once again: http://www.scootertuning.de/stage6-deve ... rkits.htmlThe photo, however, is of a WC cylinder.
| Sun Jul 10, 2011 10:08 am |
Who is online |
Users browsing this forum: No registered users and 12 guests |
