View unanswered posts | View active topics It is currently Sat Jun 23, 2018 8:39 pm
Reply to topic  [ 16 posts ]  Go to page 1, 2  Next
 Upgrading a 2008 Yamaha Zuma 50cc
Post Upgrading a 2008 Yamaha Zuma 50cc
Hello--
I am getting a 2008 Yamaha Zuma 50cc on Friday, and I want to have it upgraded to go ~50 mph. I want it to be EXTREMEMLY reliable because I am not "handy" when it comes to repairing mopeds. This is what I am thinking of getting. Please let me know if I could achieve my goal without any of these items, or if I need other items. Thanks.
Upgrade List
Malossi MHR Multivar CVT Variator: $159
Leo Vince ZX Scooter Exhaust: $200
Malossi Sport Clutch Spring Set for Original or Delta Clutch: $22
Athena Drive Belt ZUMA: $35
Uni Filter Performance Airbox - Ø 38mm: $29
NGK Spark Plug (Which one? BR7HS, BR8HS, BR9HS?: $3
Arreche Main Jet - Size 80: $4
Michelin Reggae Tires (120/90-10 or 130/90-10?): $40
Malossi Yellow Super Reinforced Torque Spring: $13
Malossi 16x13 Variator Rollers (what weight?): $17
Extras:
Motul 710 2T Fully Synthetic Oil 1 Liter
Guardian Scooter Cover: $49
STA-BIL Fuel Stabilizer Performance Improver: $7
Mon Oct 10, 2011 10:17 am
Post Re: Upgrading a 2008 Yamaha Zuma 50cc
just get a new oem belt that is the best belt out there
dont fornicate with the airbox
oem main jet is an 80 and areeche isnt even the right brand of jet for a tk carb
the zx will come with needed clutch springs
5.5 gram rollers should be in the ball park
stabil is worthless it will cause more issues then its worth use seafoam instead
Plug for the stock bore is a bpr7hs
tires one of each the front is a 120 and the rear is a 130
and if you live in a state where the epa will come down on you hard have the recall taken care of before doing any of these mods
and you still wont hit 50 mph you will do about 45 unless you port the bore
Mon Oct 10, 2011 10:24 am
Thanks jmkjr72. I changed the list, but I also added a 70cc cylinder kit + carb. Look good to go?
Upgrade List:
Malossi MHR Multivar CVT Variator: $159 (http://www.provoscooter.com/scooters/yamaha/yamaha-zuma-50-horizontal/malossi-multivar-variator-minarelli.html)
Leo Vince ZX Exhaust: $220 (http://www.scootertronics.com/leovizxyazuj.html)
Dellorto PHBN 17.5mm Carburetor with Electric choke: $190 (http://www.drowsports.com/product/573/Engine/Fuel___Air/Dellorto_PHBN_17_5mm_Carburetor_with_Electric_choke)
Stage6 Dellorto 6mm Carb Jets (Size 80-102): $25 (http://www.spmotostore.com/MAIN_JET_SET ... l5-001.htm)
Conversion Kit for Single Cable YW50 Zuma (2002+): $55 (https://www.spmotostore.com/ProductDeta ... e=SP-10002)
Athena Drive Belt: $35 (http://www.provoscooter.com/scooters/yamaha/yamaha-zuma-50-horizontal/athena-drive-belt-zuma-98-05.html)
NGK Spark Plug (BR7HS): $3 (http://www.provoscooter.com/scooters/ya ... -plug.html)
Dell'Orto Main Jet 6mm (WHAT SIZE?): $4 (http://www.provoscooter.com/scooters/yamaha/yamaha-zuma-50-horizontal/dell-orto-main-jet-large-sizes.html)
Michelin Reggae Tires: $80 (http://www.provoscooter.com/scooters/ya ... tires.html)
Malossi Yellow Super Reinforced Torque Spring: $13 (http://www.provoscooter.com/scooters/yamaha/yamaha-zuma-50-horizontal/malossi-torque-driver-spring-yellow.html)
Malossi 16x13 Variator Rollers (5.1g): $17 (http://www.provoscooter.com/scooters/yamaha/yamaha-zuma-50-horizontal/malossi-16x13mm-variator-rollers.html)
Extras:
Motul 710 2T Fully Synthetic Oil 1 Liter (http://www.motorcycle-superstore.com/2/ ... remix.aspx)
Supremeshield Yamaha Zuma Cover: $49 (http://www.vipcarcovers.com/yamaha-zuma ... cover.html)
Seafoam Motor And Fuel Treatment 16oz.: $15 (http://www.amazon.com/MOTOR-TREATMENT-M ... B0002JN2EU)
Modifications:
Dual-Headlight Modification (http://www.zumalights.com/headlight.html)
Throttle Mod (viewtopic.php?f=39&t=2702)
Are there any other modifications I should tell the mechanic to do? Such as porting the bore? Do I need to re-jet?
Mon Oct 10, 2011 10:40 am
well i personaly would get the tires from www.motorcyclesuperstore.com as zf is on there sffilate program just click on a link from in zf for them
get rid of the athean belt it is nothing but trouble oem is the best
i didnt see what kit you are looking at but a 17.5
as for jets i would stick to original del jets if thats the brand of carb you get
im on my phone so i dont have the link but i have poted up a link to where you can get the throttle tube for 15 bucks and most places have the cable for 15 bucks
Mon Oct 10, 2011 11:17 am
Alright. Here's my FINAL list. If you have any other concerns, PLEASE let me know.
Ordering as much as possible from http://www.motorcycle-superstore.com/ (ZF affiliate site)
Upgrade List:
Malossi Multivar CVT Variator: $109 (http://www.provoscooter.com/scooters/yamaha/yamaha-zuma-50-horizontal/malossi-multivar-variator-minarelli.html)
Leo Vince ZX Exhaust: $200 (http://www.scootertronics.com/leovizxyazuj.html)
Dell'Orto PHBN 17.5mm Carburetor with Electric choke: $190 (http://www.drowsports.com/product/573/Engine/Fuel___Air/Dellorto_PHBN_17_5mm_Carburetor_with_Electric_choke)
Dell'Orto Main Jet 6mm: $4 (http://www.provoscooter.com/scooters/yamaha/yamaha-zuma-50-horizontal/dell-orto-main-jet-large-sizes.html)
Michelin Reggae Tires: $60 (http://www.provoscooter.com/scooters/ya ... tires.html)
Extras:
Motul 710 2T Fully Synthetic Oil 1 Liter: $14 (http://www.motorcycle-superstore.com/2/9/197/19999/ITEM/Motul-710-2T-Racing-Premix.aspx)
Modifications:
When I bring the moped in to the mechanic for the upgrades, what modifications should I tell him to do?
Maintenance:
change 2-stroke oil every week or 500 miles
change transmission oil every 1500 to 1800 miles
change drive belt every 5000 to 8000 miles
change rollers every 1000-1500 miles
change battery every 2 years
Mon Oct 10, 2011 11:21 am
trans oil shoukd be changed every 1500 to 3000 miles
2 stroke oil added every week or 500 miles
a belt should last you 5000 to 8000 miles
check jdubby links on mss as i think they have the zx for less
If you are kitting it the plug will be an 8 or 9 depending upon the kit i may be blind as im still didnt see it in your links
if you are going to have a shop do it find out what there experiance is with moding 2 stroke scoots
and ask for refrences to scooters they have modded even if its a dealer ship
or find a guy that tunes scoots there are many of us on here that will do it for you for less then a stealership or help you thru it
ill look this over again when i get home and on a computer
Mon Oct 10, 2011 11:38 am
no problem, i really appreciate all your help!
by the way, what's the difference between transmission oil and 2-stroke oil? can i use the synthetic oil i posted for both?
Mon Oct 10, 2011 11:42 am
no do not put 2 stroke oil in the transmission. i dont see any carbon fiber reeds on your list. also make sure you tell us what bbk your using
'06 vino125 55mph 85mpg
'08 zuma50 53mph 65mpg
Mon Oct 10, 2011 1:16 pm
for the trans/final drive you need gear oil 08 to 11 spec 85/140
i have ran full synth 75/140 for 15000 miles now
Mon Oct 10, 2011 2:01 pm
OK thanks. And I wasn't planning on adding a BBK to the Zuma.
1) Would this setup still be fine without a BBK?
2) If not, which 70cc BBK would you recommend with my goals and other upgrades in mind?
BTW, I'M GETTING A 2003 YAMAHA ZUMA INSTEAD OF A 2008 YAMAHA ZUMA!
Upgrade List:
Leo Vince ZX-R Exhaust: $175 (http://www.solomotoparts.com/product.php?productid=48916&utm_source=froogle&utm_medium=cpc&utm_campaign=Froogle)
Polini Carbon-Fiber Reeds: $35 (http://cgi.ebay.com/ebaymotors/POLINI-REEDS-CARBON-FIBER-MINARELLI-BWS-ZUMA-YW50-JOG-/270790267026?pt=Race_Car_Parts&hash=item3f0c5b9092#ht_1690wt_939)
Stage6 Tuning Variator Weights: $20 (https://www.spmotostore.com/ProductDeta ... S6-GS15002)
Zuma 50 Rear Fender w/Taillight & T/S: $73 (http://www.scooterwest.com/items/?_pageCCS=t#page=/item_details/Zuma-50-Rear-Fender-w-Taillight---T-S/1842)
Extras:
Modifications:
LED Tail-Light Installation (WHERE DO I BUY NECESSARY PARTS) (viewtopic.php?f=57&t=5889)
Maintenance:
change transmission oil every 5,000 to 10,000
Mon Oct 10, 2011 2:09 pm
I would not go with the Dellorto Carb unless you are adding a BBK, even then it is not needed. If you do need to upjet, because of the pipe, you could use a Daytona 85 or Teikei 82 or 84.
I would switch to a 3 shoe clutch with 107mm bell, before changing out the variator. The clutches on 2002 - 2005 Zumas are prone to failure when used with stiffer clutch springs. Also certain aftermarket torque/contra springs sometimes bind in that clutch.
I've heard many people say the don't notice much difference swapping out the variator untill you go to a BBK. I didn't add one until after a BBK, so I don't know if you will se a benefit of not.
The Zuma 50 Rear Fender w/Taillight & T/S is overpriced, as it is a simple DIY swap, with tutorials on this forum.
Remember the tuning weights are for tuning. Once you get the weight dialed in, get proper weights.
Tue Oct 11, 2011 1:46 pm
Upgrade List:
Stage6 MKll Clutch: $140 (http://www.scootertronics.com/stage6clutch.html)
Stage6 Bell 107mm: $70 (http://www.scootertronics.com/stage6bell1.html)
Daytona 85 Main Jet OR Teikei 82 or 84
Extras:
Modifications:
Tue Oct 11, 2011 4:05 pm
You may want to consider the 107mm '08+ clutch, it is cheaper than aftermarket.
Also, you don't need the throttle cable if you aren't switching to a new carb.
Tue Oct 11, 2011 6:00 pm
Upgrade List:
Wed Oct 12, 2011 12:48 pm
Also, where can i get JUST the OEM 08+ clutch parts I need? Thanks.
Thu Oct 13, 2011 4:57 pm
Users browsing this forum: Google Adsense [Bot] and 6 guests
