View unanswered posts | View active topics It is currently Tue Jul 16, 2019 11:42 am
Reply to topic  [ 9 posts ]
 Rear wheel nut size?
Post Rear wheel nut size?
Does anyone know what it is? It's just under 1", but it's very hard to measure with digital calipers (because they're too precise).
I'm sure I can find a 1" one for my impact wrench. Will it work?
Wed May 16, 2012 5:25 pm
Post Re: Rear wheel nut size?
I'm not sure ... I'm seeing one guy say that it's 22mm ... another says that he used an adjustable wrench. I don't have a Zuma 2T so I don't really know.
But ... if it is 22mm ... then a 1" socket will not work. 7/8" might ?? ??
Wed May 16, 2012 8:36 pm
Thanks, but I have a 7/8" one and it's too small. It seems to be just under 1". When I put the calipers at exactly 1" they fit kinda loosely.
Digital calipers are too precise. I wish they had a setting to round off the result, because as soon as you change the angle a hair you get a crazy reading.
Wed May 16, 2012 9:28 pm
Next size would be 15/16" ... and since you said that ... maybe the 1" will work. I just wouldn't want you to round the corners of the nut ... if it's too loose.
Wed May 16, 2012 9:58 pm
23 millimeters = 0.905511811 inches
What I read must have been wrong in their discussion ... from all that you and I have said ...
It's got to be 23MM
Wed May 16, 2012 10:04 pm
The rear wheel nut is 24mm. The closest inch socket size would be 15/16 inch but only use a 6 sided socket or it might strip.
08 zuma 50cc
T-mod.
Thu May 17, 2012 2:23 am
Thanks SnS.
I think they only come 6-sided, though, no?
Thu May 17, 2012 10:10 am
That large you may not find anything other than 6 sided but they do make 12 sided or perhaps I should say pointed. It makes it easier to got the socket onto the nut/bolt but they also slip easier. If you use an empirical socket on a metric nut it isn't an exact fit for even more likely to slip.
08 zuma 50cc
T-mod.
Thu May 17, 2012 2:40 pm
Ah. I was thinking five sides or something and couldn't imagine what you were talking about!
Thu May 17, 2012 2:57 pm
