View unanswered posts | View active topics It is currently Mon Feb 19, 2018 7:02 am
Reply to topic  [ 22 posts ]  Go to page 1, 2  Next
 acceleration issue?
Post acceleration issue?
I'll start with a run down: 2009 Zuma 50. Performance setup: Leo Vince ZX-R, with the clutch springs and 3 of the LV rollers and 3 stock rollers, throttle mod. I have put on about 500 miles since I did all the work and acceleration has been greatly improved over stock. side note:i'm 320lbs too. The scooter tops off a little over 40mph.
issue:
Recently the acceleration has been lacking. It is kinda boggy off the line, like it almost dies off and then goes. it doesn't grab and go like it used to. Sometimes if I rev it and then off and then rev again it will take off a little smoother. If I just full on throttle from a stop it hesitates slightly and then goes but seems like it hesitates alittle up to 30mph.
besides all this. if you are cruising at 25-30mph and then full throttle it picks right up and goes. It's only from a dead stop.
I've thought about replacing the contra spring, or maybe doing a different roller setup? or both? any ideas? I feel like its just been under so much load with me on it its like its wearing out... :/
Thank you in advance!!
only a few mods and got to my goal of 40+mph and it's still a 50cc..
2009 Zuma 50cc: Throttle mod, Leo Vince ZX-R(w/clutch springs and 50/50 setup variator rollers)
Tue May 29, 2012 1:36 pm
Post Re: acceleration issue?
How many miles are on the scoot?
2003 Yamaha Zuma
TP Tophy BBK
Polini Evo reeds
Stage6 Pro Replica
Stage6 WingCooler bell
Malossi white contra
C3 Mirrors
Stage6 CNC brake levers
JDM Fender With Clear Lenses
MORE COMING SOON!!
My Zuma
ChuckD420's 2003 Zuma
Tue May 29, 2012 11:30 pm
26XX
Tue May 29, 2012 11:56 pm
It sounds like it could be a contra spring issue, but that is pretty low mileage for it to be going out. I heard the Leo rollers don't last too long. Maybe you could check those for flat spots.
Stage 6 race bore MKI-MKII wasn't available when I purchased the bore
Yasuni-R pipe
Stage 6 overrange kit-28 grams total on the rollers
Stage 6 overrange belt
OKO 28mm carb-144, 40 pilot
CT intake manifold
Stage 6 vforce reeds
Athena 14/42 gears-9.9:1 final gearing
Uni open filter
Stage 6 hpc crank-skf bearings
NGK wire-got it for free from the shop
br9hs plug
Starter (of course with the overrange trans) and oil pump removed
Some minor porting of the cases
2.5oz/gal on the premix 50:1
Stage 6 MKII racing clutch with the stock bell.
Wed May 30, 2012 12:27 am
You could also clean and re-grease the rear sheave.
http://www.zumaforums.net/phpBB3/viewtopic.php?f=39&t=17598&hilit=rear+sheave
2003 Yamaha Zuma
TP Tophy BBK
Polini Evo reeds
Stage6 Pro Replica
C3 Mirrors
MORE COMING SOON!!
My Zuma
Wed May 30, 2012 9:24 am
Are these flat spots totally obvious? like should I roll them on a table? or?? What is the weight of the stock rollers so I know what to buy? I've greased that sheave.
Wed May 30, 2012 9:25 am
if you are running 1/2 and 1/2 you should have a spare set to put on
yes the flat spots should stick out like a sore thumb
im not a big fan of mixing when the weights are more then .5 gram diffrent
as one tends to slide insteaf of roll
if you are at 1/2 and 1/2 then order a proper set of 5.5 gram rollers
order a new set of medium clutch springs
stock is 6.9 and leo are 4.3
i dont think its a contra issue as it only happens on inital take off that would tell me clutch springs
and the leos are know to go bad fast
Wed May 30, 2012 9:33 am
Wow I wasn't aware that they were so far apart. So that does make sense. I will order that today.
What would cause the the little springs to go bad? What prevents a new set from going bad just as quick if they are actually bad? Should I just go ahead and get a tougher clutch spring to have the same stuff through out? Like a 1.5k rpm contra, springs. and then do the 5.5 gram roller set.
Wed May 30, 2012 9:45 am
For reference. The stock rollers in my 2009 weighed out to 7.5 grams each.
_______________________________________
The Rumrunner:
'09 Zuma 50.
Top Performance Trophy 70cc, Stage6 small end bearing, 2005 carb needle raised one notch, Malossi carbon reeds, 84 main jet from Yamaha, Throttle mod, LeoVince TT, Polini Speed Contol variator (#241-301), Hoca Racing drive face, 7g adige sliders, Malossi yellow torque spring, dual headlight mod, triple brake light mod with LEDs, LED plate light, less bulbous turn signals, 12v power port, Air horn, RAM GPS mount, 15W fork oil, Shinko SR 426 4 ply Dual Sport tires, Ducted trans cooling with a fan up under the cowling so I can still ride through mud.
Build thread: viewtopic.php?f=50&t=19720
Wed May 30, 2012 9:53 am
Mines were 7.5 in my 09 also. I have read others saying theirs were 7 grams though.
Yasuni-R pipe
CT intake manifold
Uni open filter
br9hs plug
Wed May 30, 2012 10:15 am
yeah the rollers are all over the place on the zuma
some came as light as 6.0 stock
the leo springs are just crap that is why they wear out fast
i have had pretty good luck with the ncy medium springs lasting 7000 miles
heat is basicly there enemy and stock there is no venting in the belt cover but its funny just about all the cheap clones vent the trans but yamaha doesnt
so you may want to get a set of 5.5 and 6.0 rollers and see what is better
Wed May 30, 2012 10:29 am
Parts are on there way. Thank you for the help!! :cheers:
Wed May 30, 2012 11:02 am
Forgot to update this post. I pulled it all apart and rolled the rollers on my table and yep they have flat spots. Thanx for the help. I'm just amazed that they flat spotted in 400-500 miles.
Sat Jun 02, 2012 8:33 am
so did that fix your problem? reason why i ask is i had the same issue and rollers/vario didnt help i actually replaced the clutch unit and it fixed it. but mine had a pretty severe bog at 1-3 mph.
2004 zuma - 70cc athena
2005 zuma - 70cc athena SP3 exhaust
Sun Jun 03, 2012 9:44 am
Not sure yet. The new parts haven't come yet. I will update as soon as I get back together.
Sun Jun 03, 2012 11:57 am
Users browsing this forum: No registered users and 9 guests
