View unanswered posts | View active topics It is currently Sun Apr 22, 2018 12:50 pm
 Big bore kit and oil injection...
Post Big bore kit and oil injection...
Does the oil injection system supply enough oil for a big bore kit? Does it need to be modified in some way? Do you have to mix in some 2T oil with each tank of gas? Or, do you just need to be sure to run a really good synthetic oil? Thanks!
--Tom
Sat Aug 08, 2009 11:01 pm
Post Re: Big bore kit and oil injection...
My 08 Zuma's oil injection is around a 40:1 ratio I think. ( I have been told at least) For my Athena 70bbk, it was sufficient lubrication.
Not sure about other kits. I'm installing an MHR kit and I have been told that it won't be sufficient. Have not verified it yet though.
Sun Aug 09, 2009 12:01 am
40-1 at 50 cc. its far from 40-1 now that displacemeant has been increased to 70cc. i run mine at 40-1 pre mix with a good synthetic oil.
Sun Aug 09, 2009 8:30 am
as long as you stay in the sport kit catagory the 40:1 stock system should be just fine (most of us with this type of kit are still running it without adding any extra oil)
now once you start getting more wild in your build and into the race and mid race kits then it is not enough oil also some carbs do not work with oil injection so carb selection needs to be considered too
almost every mile on both of my 2 strokes (stella and zuma) are full syth
the only miles that were not on the zuma was the tank full of yamaha lube that it came with
the zuma has over 10000 miles on it 8000 miles on a stock bore with out a rebuild and it didnt realy need anything at that point i just wanted more
i currently use ipone as it was desinged specifiacely for scooters
Sun Aug 09, 2009 8:32 am
i just add a cap full of injection oil to a full tank of gas. works fine for me. smokes a lil but better to have more then none.
Pro Scooter Parts Authorized Dealer
Polini / Malossi / NCY /Metrakit / POSH / Doppler / Leo Vince / Athena
Visit us today at http://www.proscooterparts.com
60+ mph club 70+ when i can show the proof :)
Sun Aug 09, 2009 7:13 pm
a 70cc kit is a 40% increase in displacmeant. i wounder what the oil ratio in a big bore comes out to when using the oil injection. i pre mix at 40-1 and have no worry's.
Sun Aug 09, 2009 8:12 pm
Users browsing this forum: Google [Bot] and 4 guests
